Old 20-10-12, 04:45 PM   #1
Nick_69
Nick_69's Avatar
Default Briaded hose change - leak.
I have been upgrading my brake lines on my GSXR 600 k9, i was doing the rear one first and when i went to bleed the brakes the rear banjo was leaking fluid, i have made sure that the banjo bolt was tighten to the correct amount. Does any one has a reason why this might be happening.
Was SV650S K9
Now GSXR 600 K9
Old 20-10-12, 06:36 PM   #2
Lawman
Default Re: Briaded hose change
Did you use new washers or soften the old ones?
The copper work hardens and can leak.
Old 20-10-12, 06:40 PM   #3
squirrel_hunter
squirrel_hunter's Avatar
Faulty banjo?
"A little enthusiastic?"
SH2 | 2MA | GROM | YSR
Old 20-10-12, 07:56 PM   #4
Nick_69
Nick_69's Avatar
New washer where used, could be fault banjo will check tomorrow
Was SV650S K9
Now GSXR 600 K9
Old 20-10-12, 08:48 PM   #5
Try two washers?
Fork spring change - change oil? GIZZY66 SV Talk, Tuning & Tweaking 14 05-02-12 04:59 PM
Leak after oil change. Bourbon21 SV Talk, Tuning & Tweaking 13 30-05-11 06:33 PM
Reasons for coolant to leak from breather hose? dizzyblonde Bikes - Talk & Issues 24 15-04-11 10:37 AM
Change in weather= Change in diet Dicky Ticker Idle Banter 5 15-08-06 06:51 PM
Not oil leak - Petrol leak - double "Bugger"...! Potts SV Talk, Tuning & Tweaking 1 17-10-04 08:16 PM
