Old 29-01-13, 08:49 PM   #1
Winder
Winder's Avatar
Default What grease to use on bolts?
I have started using copper grease on all my bolts and behind my pads as my old curvy had almost every bolt rusted solid. Is copper grease the best thing to be using or should it only be used on bolts that are in areas that will get corroded easily like bottom yokes and brake calipers etc?
Old 29-01-13, 09:05 PM   #2
Default Re: What grease to use on bolts
Yep I can't think of many bolts you shouldn't use them on. I know brake caliper seals don't like copper grease, but behind the pads is fine.
The only ones you shouldn't use cppoer grease on are ones which use loctite on, to stop them coming undone, ie disc rotor bolts .
Old 29-01-13, 09:31 PM   #3
As above.
I use a mix of copper grease and studlock on places where they can sieze solid ie: fork leg lock bolts, caliper mount bolts.
Did this for a few years and not had any issues
Old 29-01-13, 09:54 PM   #4
tigersaw
tigersaw's Avatar
I put in on threads everywhere, other places that just need some general grease like axles etc I use ACF50 grease.
Old 29-01-13, 10:43 PM   #5
Winder
Winder's Avatar
Thanks guys, just thought you might be using something different or new. My mates ZX10 is basically covered in ACF 50, i mean fairings, frame, forks, exhaust the lot. Didn't know it was grease? Thought it was more of a protective laquer or film or something?
That's interesting, thanks.
Old 29-01-13, 10:45 PM   #6
Tomor
Tomor's Avatar
Acf also make a corrosion resistant grease. I use that on most places and acf spray everywhere else.
Yam XT125R - Sold SV650 -Sold DL 650 K6 - Sold
2012 Street Triple R - For Sale - Linky here
Tomor is offline   Reply With Quote
Old 29-01-13, 10:49 PM   #7
squirrel_hunter
squirrel_hunter's Avatar
I wouldn't recommend using copper grease on banjo bolt threads. And yes I have seen this being done. And no it was not me.
I only noticed he had done it when he came to the second caliper, so he then had to strip that caliper down as well as the first one to ensure it was all cleaned out.
"A little enthusiastic?"
SH2 | 2MA | GROM | YSR
Old 29-01-13, 10:54 PM   #8
Winder
Winder's Avatar
Ha ha. Close call.
Old 30-01-13, 12:59 AM   #9
As above.
ermmm that pretty much defeats the purpose of threadloc
Old 30-01-13, 07:07 AM   #10
It works tbh, the threadlock works as a stiffening agent with the copper grease
sent from a phone
Seat bolts and infill bolts wanted sv curvy Joe Marcon Stuff Wanted 0 14-06-12 10:06 PM
Lithium grease / Castrol red rubber grease DarrenSV650S Bikes - Talk & Issues 25 22-01-10 09:59 AM
Grease pmapp Bikes - Talk & Issues 18 08-03-08 12:50 PM
grease latts650s SV Talk, Tuning & Tweaking 2 24-02-06 07:20 PM
Long bolts? Short bolts? andyaikido SV Talk, Tuning & Tweaking 6 25-01-06 04:53 PM
