Old 25-06-13, 10:51 PM   #1
bikerjay
Default Wheels on different SV models?
Hi,
Am I right in thinking that the wheels are the same on the sv's through the years?
Thanks, jay.
Old 25-06-13, 11:13 PM   #2
Default Re: Wheels on different SV models?
no pointy curvy are different
Old 26-06-13, 10:22 AM   #3
DaveW_42
DaveW_42's Avatar
you can get adapter kits though
K4 trackbike, a black K8 S loaded with my spares and a 1989 CBR 400 TriArm with all the trimmings.
DaveW_42 is offline   Reply With Quote
Old 26-06-13, 10:32 AM   #4
bikerjay
I cant see much difference from looking at pictures, I think it will be a case of different spacers. Just got some cheap for a spare set of intermediates. So long as I can swap between pointy and curvy wheels.
Thanks, jay.
Old 26-06-13, 10:46 AM   #5
jambo
jambo's Avatar
I believe the rear wheels are the same physical piece with different spacers & bearings, the front wheels are different as they have different hub widths (discs on the curvy are dished rather than flat)
Jambo
Old 26-06-13, 10:56 AM   #6
bikerjay
Nice one, thanks.
I think I should be able to get them to fit. Front wheels arent usually too much of a problem, its the rear wheel that can be tricky. So long as the sprocket hub lines up the shouldnt be too bad.
Thanks, jay.
Old 26-06-13, 11:28 AM   #7
wideguy
I put an '09 front on my '00.
The hub is wider, so I had to move the speed sensor to the rear wheel. I used the right rear spacer (replaced by the speed sensor) in the front, and had to shorten both it and the original right front spacer.
Also had to shave some off the rear brake hanger, since the speed sensor is wider than the original spacer.
Old 26-06-13, 11:38 AM   #8
bikerjay
Thanks mate, the picture is coming together now. So the older one is narrower, I should be able to nock up some spacers on the lathe no problem. just need to make sure I get it so I can swap from one set of wheels to the other.
Jay
Old 26-06-13, 01:05 PM   #9
squirrel_hunter
squirrel_hunter's Avatar
Any more details on how you moved the speedo drive please?
"A little enthusiastic?"
SH2 | 2MA | GROM | YSR
Old 13-10-14, 10:13 AM   #10
JKRacing
Was it hard to adapt the wheels to fit to the pointy?
Glamour models, mum and me. Reeder Idle Banter 12 14-12-11 09:31 PM
Different models, sport etc? svv SV Talk, Tuning & Tweaking 7 13-09-11 11:43 PM
real or models ????? jans1971 Idle Banter 28 14-05-09 10:27 AM
2008 Models Wayluya SV Talk, Tuning & Tweaking 15 22-02-08 08:03 PM
differences between K3 and K4 models - help! benny SV Talk, Tuning & Tweaking 4 14-03-05 11:33 AM
