I'm away to put in new dog bones into the bike , will it be ok using an Abba stand to do this ? thanks
Should be!
I used axle stands with the pegs reversed and its fine ![]()
#3 | |
Couldn't get my shock and dog bone bolts undone so had to get a garage to do mine. Typical Japanese problem, they seem to have an adversion to using anything remotely resembling grease. Suggest a good coat of copper slip on all the moving parts whilst you are in there and then its done. Pete
It's official, the iconic naked curvy SV650 are now classics ![]() |
#4 | |
Use the ABBA Stand in the swing arm if you have one available it makes the job a lot easier. |
Aha, good point, I was thinking of a paddock stand.
Pete
thanks for that , Monday night job , just was worried that swing arm would fall down when bolts removed , will give it a go ,
thanks |
The swing arm will drop a little so the rear tyre will be resting on the ground (the ABBA Stand takes it off the ground). Though I can't honestly remember if it will do that with just the dog bones being removed as I am usually swapping shocks so take the whole set up apart anyway. As a tip, a block of wood comes in handy to stick under the rear wheel to raise it up a bit and make refitting the suspension bolts a little easier.
hard changeing gears when cold | craig dow | SV Talk, Tuning & Tweaking | 14 | 14-09-12 08:36 AM |
changeing speedometer bulb | Elio | SV Talk, Tuning & Tweaking | 9 | 06-07-06 01:25 PM |
changeing dash bulbs | BIKER-DENE | Bikes - Talk & Issues | 4 | 04-05-06 04:27 PM |
dogbones | madEG | SV Talk, Tuning & Tweaking | 2 | 17-05-05 03:56 PM |
