Old 20-07-13, 11:59 AM   #1
Braindead101
Default I'd like your recommendations, please...
... I'm after a multimeter - I'll only need it for occasional, bike related use - they seem to be available for any price from £5 up - is there a particular brand / model that people would go for, or do they all do pretty much the same thing? I don't want to spend more than I need to, but I'd like it to be fit for purpose.
Thanks in advance.
Old 20-07-13, 12:10 PM   #2
Wideboy
Evel Knievel
Wideboy's Avatar
Default Re: I'd like your recommendations, please...
don't know much about them but i've had a few cheap ones, they tend to be alright for occasional use but the leads don't seem to be heavy duty enough on the cheapo one's.
I invested in a draper one eventually for 30 odd quid and it works pretty nicely.
05 DRZ400E
RIP hovis
Old 20-07-13, 12:12 PM   #3
All you will need is a volt meter, continuity tester and possibly an ohmmeter. Pretty much all of them will have those functions. Might be better to get one that takes a 9V battery rather than those small camera batteries.
If you won't be using it regularly, it makes no sense spending more than £10-£15
Old 20-07-13, 10:12 PM   #4
Bluepete
Bluepete's Avatar
Maplins are usually good value.
Pete
Old 20-07-13, 10:53 PM   #5
squirrel_hunter
squirrel_hunter's Avatar
I use the Clarke CDM20 from Machine Mart. Does everything I need it to and more.
"A little enthusiastic?"
SH2 | 2MA | GROM | YSR
Old 21-07-13, 05:52 AM   #6
Braindead101
Thanks for the advice guys, it's helped a lot.
Old 22-07-13, 09:42 AM   #7
ClunkintheUK
Cheap meter, get decent leads though. My dad is an electronics engineer, he uses the leads from his now dead multimeter from years ago, and a 5 quid meter form maplin.
Old 22-07-13, 10:18 AM   #8
jambo
jambo's Avatar
Make sure it measures up to 100V AC, 20V DC, and measures DC voltage in 0.1V measurements. Ended up with a cheap one that only worked in 1V increments a while back, makes some diagnosis harder.
Jambo
Old 22-07-13, 11:45 AM   #9
phil24_7
Mine is blue if that helps!
Any recommendations please appollo1 Idle Banter 18 20-06-13 07:28 AM
Top box recommendations? flak monkey SV Talk, Tuning & Tweaking 9 04-10-10 05:43 PM
Sat nav recommendations? Cornish Bikes - Talk & Issues 24 17-09-10 04:38 PM
MOT Recommendations ? Cam_73 SV Ecosse 6 22-01-07 09:53 AM
recommendations on oil si-dall SV Talk, Tuning & Tweaking 17 07-02-06 07:14 PM
