Old 08-09-13, 07:45 PM   #1
Matt-EUC
Default Curvy engine.
Cheap. Preferably with less than 20k on the clock. Until I get the time to have a good look at my knackered one, I may accept one with a ****ed crank.
Old 28-12-13, 02:08 AM   #2
Matt-EUC
Bump.
Old 28-12-13, 08:57 AM   #3
Default Re: Curvy engine.
Ebay there was one for 200 quid before Christmas
Sent from my ST25i using Tapatalk 2
Old 28-12-13, 11:08 PM   #4
Matt-EUC
Can't seem to find one. There's a pointy engine on fleabay but I'm not certain the innards are compatible.
Old 28-12-13, 11:09 PM   #5
Pointy to curvy is the alternator and clutch off the curvy IIRC
Old 28-12-13, 11:12 PM   #6
Matt-EUC
Only the alternator and clutch is different??? Hmm... Might be something to look into.
I'm not sure if you know the story but I dropped a valve through oil starvation. So I'm pretty sure I only need certain innards. If the guts are the same then it may be much simpler.
Old 28-12-13, 11:15 PM   #7
Dropped valve is piston, valve and head
you sure its just top end starvation?
Old 28-12-13, 11:16 PM   #8
Matt-EUC
Not a clue. I still haven't had the courage to open her up.
Old 28-12-13, 11:24 PM   #9
Split her and see the damage
Old 28-12-13, 11:41 PM   #10
squirrel_hunter
squirrel_hunter's Avatar
What's needed to change with the clutch?
If you do go for a pointy engine in a curvy frame ensure that its single spark. You will need to also swap the inlet rubbers for the carbed version. And then there is the oil cooler my understanding is there might be clearance issues with the standard exhaust which may be overcome with using the pointy header pipes. I've not done this swap myself but have looked into it before.
There are some other subtle differences and I'm not sure 100% of the solutions for example the PAIR takeoffs from the valve covers might be overcome by swapping with the curvy.
But yes the alternator needs changing not a big job. Just make sure its done up tightly enough as I've seen the damage when its not.
"A little enthusiastic?"
SH2 | 2MA | GROM | YSR
I want(need) a curvy engine Serdna Stuff Wanted 2 06-11-12 09:30 AM
Curvy engine Winder For Sale - SV's and SV related items 3 05-03-12 04:04 PM
Engine parts and a complete engine for sale as well as other curvy spares EssexDave For Sale - SV's and SV related items 10 23-01-12 08:41 AM
Engine for curvy stuballs Stuff Wanted 0 09-06-10 08:12 PM
Curvy Engine SVmonkey Stuff Wanted 4 01-11-07 11:57 PM
