Old 18-04-14, 03:37 PM   #1
dylandun
Default 1 hour diagnostic and still waiting
so... i took my bike to the garage last Friday because it was playing up. so i put the bike in for a 1 hour diagnostics but on my way there the bike starts to cut out so the trip wasn't as pleasant as id hoped the original issues were dropping revs, little sluggish, poor fuel consumption and a few other annoyances and me being not the most technical of people decided to let the professionals handle it.
its now been a week they rang me up yesterday to tell me they were not able to get it started on the hour diagnostic and that they think the alarm is causing it not to start and they wanna disconnect it and spend the remainder of another hour trying to find the problem... im so dreading the cost of fixing my bike if its already cost me £140 to find the problem but its good Friday they aren't open and i don't even know if the place is open atall this weekend so looks like im stuck another week getting the bus to and from work :/
anyone have any opinions? would the alarm out of the blue stop the bike from starting?
Old 19-04-14, 12:12 PM   #2
SV650Racer
Default Re: 1 hour diagnostic and still waiting
Yes if the alarm is faulty it can stop the bike being started.
Old 21-04-14, 07:53 PM   #3
L3nny
L3nny's Avatar
Alarms are noting but trouble, just get the thing removed. Shouldn't take them long.
2015 GS 1200 Adventure
Old 22-04-14, 12:25 PM   #4
ReformedNiceGuy
Originally Posted by dylandun View Post
dropping revs, little sluggish, poor fuel consumption...
Those all sound like ignition problems - have you checked your spark plugs? Might also be worth looking at your air filter too.
These are all easy jobs you can do yourself in an hour!
Old 22-04-14, 10:07 PM   #5
muzikill
muzikill's Avatar
Garages that fit bike alarms must love get paid to fit them and then 2 years later to remove them!
Sent from my GT-I9505 using Tapatalk
Old 22-04-14, 10:09 PM   #6
dylandun
could it cause poor running over a long period of time?
also they still haven't got round to it !
really hate public transport
Old 24-04-14, 02:53 PM   #7
dylandun
Rang up today.. apparently the mechanic is still scratching his head to why it wont start and this is 2 hours later.. i really want to know who is looking at my bike because this is starting to cost me an arm and a leg for a diagnostic and they cant even get it started
Old 24-04-14, 05:36 PM   #8
Scythe92
My SV had poor running like this and just wouldn't rev, it was a HT lead to provides your ignition coil with power which has degraded with time. This was a carbed Curvy though.
Old 24-04-14, 09:47 PM   #9
dylandun
still a possibility ill ask them about it tomorrow! thank you
Roadside diagnostic and fix test Mark_h Bikes - Talk & Issues 77 15-10-12 09:33 PM
£400 an Hour gettin2dizzy Idle Banter 60 18-08-10 09:15 PM
16.03.09 - got an hour or so? Dappa D South & West Surfers 5 11-03-09 04:19 PM
Diagnostic plug DavieSV SV Talk, Tuning & Tweaking 1 11-01-08 08:54 AM
Charging problem, need diagnostic help!!! Troy SV Talk, Tuning & Tweaking 12 20-09-04 11:21 AM
