Old 10-06-14, 04:54 PM   #1
Dunn-y
Default Fitting aftermarket horns
The stock horn on my ZX9 is quite dull and croaky so I've bought some twin snail shell type horns but don't know how to fit them or wire them up.
All that came in the pack was the brackets to attach it somewhere on the bike.
The only place where there is enough room to fit them both is between the engine and battery.
These are the horns I bought http://www.ebay.co.uk/itm/BIKE-IT-TW...item2c7c18dbde
Any help appreciated. Thanks
Old 10-06-14, 05:01 PM   #2
Luckypants
Luckypants's Avatar
Default Re: Fitting aftermarket horns
This has been asked many times so a quick search turned up Rictus' fitting instructions...
http://www.sv650.org/docs/FIAMM%20DU...C%20HORNS2.doc
You will have to adapt for fitting to your bike but the basic premise is correct. Things like where to fit and bending the brackets etc are specific to a curvy but the wiring and mounting is true for any bike. The horns you bought are very similar to Fiamm horns.
Old 10-06-14, 05:18 PM   #3
Dunn-y
Thanks. I tried doing a search on my phone at work but nothing came up.
Can't view that file without installing crap on my computer.
I'm guessing I also need a relay, fuse, and some extra wiring to actually fit them.
Fitting aftermarket bar ends? PuggledPrune SV Talk, Tuning & Tweaking 7 10-05-11 02:13 PM
Fitting an aftermarket can L3nny SV Talk, Tuning & Tweaking 7 29-04-09 12:06 AM
aftermarket silencer fitting jcuff86 SV Talk, Tuning & Tweaking 10 25-04-08 11:07 PM
Fitting Aftermarket barends Muttley SV Talk, Tuning & Tweaking 2 24-04-05 01:50 AM
fitting aftermarket indicators 650newb SV Talk, Tuning & Tweaking 16 05-03-05 06:35 PM
