Old 17-06-14, 06:21 PM   #1
zombie
Default Exhaust clamp - look right? Pointy
Hi
I found a rusted and broken exhaust clamp (attached). I have swopped for a new one from wemoto and tightened it. Does this look right? I am not sure what they are supposed to do, other than tighten the end of a large pipe over a smaller one.
Its a Fuel can on a K5.
(black colour is just from electrical tape)
Thanks
Old 17-06-14, 06:30 PM   #2
DanSp
Default Re: Can clamp - look right?
Ive been running mine without that clamp for the last year.... never been a problem so far!
Old 17-06-14, 06:37 PM   #3
PyroUK
PyroUK's Avatar
Default Can clamp - look right?
Looks fine, just new and shiny against old and hagered.
Can't quite tell but looks like the bolt is in a different position to the last so maybe that's why it looks odd
2011 Triumph Daytona 675, Arrow exhaust and QS!
PyroUK is offline   Reply With Quote
Old 17-06-14, 07:15 PM   #4
Creaky
Think you have the new bolt on the outside whereas as pyrouk says original was on the inside. If you turn the bracket over it should look tidier.
Creaky is offline   Reply With Quote
Old 17-06-14, 07:59 PM   #5
squirrel_hunter
squirrel_hunter's Avatar
The original clamp that has rusted off is actually welded onto the back section of the pipe work. It just clamps the bigger pipe over the little one to seal the exhaust system. While it does obviously do a job if its rusted off and there are no exhaust gases escaping then chances are the pipe has rusted itself sealed tight together anyway. But there is no harm and as you have done in replacing it.
"A little enthusiastic?"
SH2 | 2MA | GROM | YSR
Old 17-06-14, 09:10 PM   #6
zombie
Thanks for your comments guys. I am reassured.
sv exhaust clamp craigr91 Stuff Wanted 1 16-06-10 11:58 AM
Exhaust clamp - where from? Surfjayce Bikes - Talk & Issues 8 06-04-10 08:39 PM
handlebar clamp maultin SV Talk, Tuning & Tweaking 3 05-02-08 12:10 AM
exhaust clamp DoubleD Stuff Wanted 2 29-09-06 09:48 AM
Exhaust Clamp size jon SV Talk, Tuning & Tweaking 12 23-05-05 12:29 AM
