Old 07-07-14, 04:45 PM   #1
Badeye
Default Carb balancing advice?
Hi Guys,
Been having a go at syncing my carbs but using a mates own made manometer i believe has knocked them out of sync worse to the point where the bike isn't starting. I have managed to borrow some proper mechanical gauges to get them sync'd but the screw is well out.
Is there a default position i can put the screw to just to get it up and running again.
Just so you know the bike only stopped running when i started messing with the sync screw. Which way when screwing it increases and decreases vacuum?
Thanks in advance.
Si
Old 07-07-14, 04:52 PM   #2
Default Re: Carb Syncing Advice
have you been turning up/down the idle screw while you are adjusting the vacuum?
Old 07-07-14, 05:23 PM   #3
bobbleheadbarne
Bad eye close them fully then take two turns back out it should start but run ****ty
Old 07-07-14, 05:24 PM   #4
bobbleheadbarne
U have a set of twin morgan carb tune for sale cheap mate
Old 07-07-14, 05:30 PM   #5
embee
embee's Avatar
Best way to get them basically close is to back the idle stop right off so the butterflies should both be fully closed. With the screw backed off, adjust the balancing adjuster so they are both as near as you can tell going fully closed, check this by looking into the intakes (lift the slides as necessary, don't drop anything in there!). You can usually feel when the butterfly "bottoms out" if you are careful.
Then adjust the idle stop screw up a bit and it should be close enough to get you started.
Old 07-07-14, 05:39 PM   #6
bobbleheadbarne
As embee says...better than I put it ll
Old 07-07-14, 09:21 PM   #7
Badeye
Thanks for the advice guys, i'll give it a blast 2moz and report back.
Old 08-07-14, 05:07 AM   #8
johnnyrod
johnnyrod's Avatar
Default Re: Carb balancing advice?
How have you got the rear cylinder connected up to the gauges?
Carb syncing fuel question. daveyrach Bikes - Talk & Issues 32 12-04-13 09:52 AM
7.5k service carb syncing advice? charlie53 SV Talk, Tuning & Tweaking 10 23-03-11 05:25 PM
Carb advice Davi1033 SV Talk, Tuning & Tweaking 3 04-04-08 03:07 PM
Carb syncing at 4000RPM not Idle!?.. kciN SV Talk, Tuning & Tweaking 19 11-05-06 02:08 AM
Carb syncing svrash SV Talk, Tuning & Tweaking 2 13-02-06 09:01 PM
