Old 08-06-15, 05:50 PM   #1
Swin
Swin's Avatar
Default Chain Lube
I've been reading on another forum how some folk use WD40 to lube their chain, and I can see the attraction, I use a brush and sparingly apply a mix of chain lube and oil to the chain on my pointy, even with a thin layer my back wheel cruds up in no time.
I guess WD40 would be great in this respect as it's a thinner texture and can be applied with a brush or cloth, so it's got me thinking of this as an alternative to my current method.
Anyone got any experiences/opinions, good/bad - all are welcome
Riding a V-strom, well it has an Sv engine, don't it
Swin is offline   Reply With Quote
Old 08-06-15, 06:18 PM   #2
Nutsinatin
Nutsinatin's Avatar
Default Re: Chain Lube
I fail to see what lubricating this is actually going to do, and don't suspect that this will do the rubber O rings or the grease they are trying to retain any good unless you are using a solid chain. I prefer to use a Scottoiler which is self cleaning and doesn't make a mess if you set it up right, but as I need to fit it to the new bike still I've been using a dry lube like this, zero fling and minimal pick up, cleaning the chain about every 1200 miles. It doesn't stick that well in the wet though, so needs frequent reapplication if you ride in the rain. You could also brush on gear oil like suggested in most motorcycle owner book and see how that goes?
Blue K9 Pointy - Squished by a car/kerb/wall
Blue K9 Pointy #2 - Nearly at 120,000 miles!
Nutsinatin is offline   Reply With Quote
Old 08-06-15, 06:25 PM   #3
Phoenix22
I wouldn't rely on it as a lubricant & some may say it damages the rubber O rings.
I have to confess to being a bit compulsive about chain maintenance & like my chain to look like new at all times without any splatter onto the rear wheel rim. After every ride I use Wurth dry chain lube then just wipe the OUTSIDE of the chain with a rag soaked in WD40. Best of both worlds. Last chain lasted 25K treated this way & even then had plenty of life left.
Old 08-06-15, 06:47 PM   #4
Do not use WD40 for chain lube! Its a degreaser, I wouldn't even use it to lube my pushbike chain.
It has nothing to stop it getting flung off the chain, so has no lubricating benefits
Its great for cleaning crud off the chain, but paraffin is better
Use a proper chain lube, there's lots out there
If you use a wax based lube, you don't get to much fling, if you're mixing lube and oil its going to destroy the properties of the chain lube?
Buy a scott oiler, a tutoro or a PDQ chain oiler, as these use the right sort of lube and will extend the life of your chain. Chains like being run in a chain bath, but these are the next best thing
Fling is normal, no matter how good the lube
Old 08-06-15, 06:59 PM   #5
carelesschucca
carelesschucca's Avatar
I wouldn't touch WD40 as a chain lube. Either get a proper good quality chain lube or something like a scottoiler that once its set up makes life very simple and keeps maintenence down, yeah its a bit of an outlay initially but I've used the same oiler on all of my bikes. Buts thats just me a cheapskate, with a nice clean chain and dirty back wheel.
Old 08-06-15, 07:42 PM   #6
NTECUK
NTECUK's Avatar
WD 40 is good for getting grease off. Great for cleaning processor heat sink face before fitting a new heat sink.Good to disperse water too.
It's no resilience as a lubricant.
It's also going to adversely affect the o rings in the chains links.
Old 08-06-15, 07:42 PM   #7
Swin
Swin's Avatar
Thanks, I'll give this Wurth dry stuff a try, it seems to be exactly the product I'm looking for - looks to be very reasonably priced too.
Old 08-06-15, 07:45 PM   #8
Littlepeahead
Littlepeahead's Avatar
It's good but once the chain is dirty it is very tricky to get off.
Old 08-06-15, 07:48 PM   #9
Swin
Swin's Avatar
I have a can of chain cleaner that I've never had to use with my "brush and jam jar method", so perhaps I'll need to make use of that before re-lubing
Old 08-06-15, 07:50 PM   #10
I use Castrol chain wax, very good, not too much fling, got good reviews
You can get it at Halfrauds
Which chain lube (or just oil?) stuR Bikes - Talk & Issues 25 24-04-13 12:07 PM
S-DOC Chain Lube? krhall Bikes - Talk & Issues 3 03-03-10 09:28 AM
Used oil for chain lube sunshine SV Talk, Tuning & Tweaking 26 27-09-09 09:39 PM
How much lube? (Chain lube!) AndyL SV Talk, Tuning & Tweaking 10 10-01-09 08:04 PM
Chain lube. furrybean Ancillaries 17 02-11-07 06:33 PM
