Old 31-05-17, 08:46 AM   #1
daktulos
daktulos's Avatar
Default Tank questions
Hi,
I have two tank-related questions. Firstly, my filler cap is very stiff and I think needs a good clean (see photo below). Do you have any ideas of what would work well to clean it up without damaging the rubber or contaminating the petrol, or should I be looking at a replacement?
Secondly, does anyone know what is used to glue on the rubber cushions on the side of the tank, that sticks but won't damage the paint?
Thanks!
daktulos is offline   Reply With Quote
Old 31-05-17, 09:18 AM   #2
squirrel_hunter
squirrel_hunter's Avatar
Default Re: Tank questions
That's just a little surface rust and nothing to worry about. Wipe it over with WD40 and then the same to lube the lock. Spray it on and work the mechanism. Its not going to contaminate the petrol, I've done this myself.
As for the glue, I didn't think they were glued on?
"A little enthusiastic?"
SH2 | 2MA | GROM | YSR
Old 31-05-17, 09:20 AM   #3
daktulos
daktulos's Avatar
Hah! It's probably 17 years of random gunk keeping them there, then!
Thanks.
Old 31-05-17, 03:02 PM   #4
R1ffR4ff
R1ffR4ff's Avatar
Get some ACF50.I use it all over the bike.Seems costly but goes a long way,
http://www.ebay.co.uk/itm/ACF-50-Ant...cAAOSwPCVX4l2B
Great lube and anti-corrosion treatment.I also use it in and on all my electrical connectors/bulb holders etc as well as the hinges and locks on my fuel cap/ignition.
If you don't know what it is read here,
http://www.acf-50.co.uk/motorcycle.htm
HTH
Old 31-05-17, 03:33 PM   #5
daktulos
daktulos's Avatar
I have ACF50, but I still think it needs a good clean first.
Old 31-05-17, 05:15 PM   #6
R1ffR4ff
R1ffR4ff's Avatar
Yeh.You don't want any crud getting into the tank as I understand the fuel filters are pretty small on these bikes.I had external in-line ones on my Hondas.Way easier to keep clean.
Questions, questions - light bulbs and oil leaks. garynortheast SV Talk, Tuning & Tweaking 7 25-03-10 12:55 PM
Battery charging and tank raiser questions. allantheboss Bikes - Talk & Issues 14 03-02-10 02:58 PM
Fuel and tank questions. hindle8907 Bikes - Talk & Issues 15 17-06-09 07:17 AM
Questions questions...(funny noise,luggage, ferry) the_lone_wolf SV Talk, Tuning & Tweaking 23 23-05-07 07:19 PM
a few questions....well 5 questions....from a newb flynn209 SV Talk, Tuning & Tweaking 12 10-07-06 10:56 PM
