It started a Week ago.
I was riding at 40mph - suddenly the petrol light came on - Speedo & rpm meter died for about 5 seconds. Then worked fine again. Since that it mailfunctions more frequently. Yesterday it didn't work at all. Indicators, lights all work - it's just the speedo & rpm meter that seems to have a fault. I already checked all the cables/connectors under the front fairing - no problems there. Any ideas what might be wrong ? |
I've had similar sort of thing rearing its head occasionaly. Does the engine die momentarialy also?
no bike keeps running fine.
trace the wires back and they should come into a plug unplug and check for any oxidised connections (green wires) as they snap very easily and can cause blips in electrial systems when the bike is jerked or you hit a pot hole
I had a similar thing happen just before the bike ate its regulator. So I would check the charging system and battery just to be on the safe side
check charging system, not only cold, but after completely warmed up for a half hour or so,
I think i found the problem.
There was something wrong with the main fuse. It wasn't blown but the element looked "worn" on one side. So I changed it with the spare one and it seems to work now - well at least while the bike is standing. I will take it for a test run later. Oh and by the way - be careful with pliers - me being a clumsy XXXX I electricuted myself ![]() |
Speedo & Tacho Dying | Normski | SV Talk, Tuning & Tweaking | 5 | 23-07-08 11:15 AM |
Stress Meter | plowsie | Bikes - Talk & Issues | 6 | 16-10-07 11:01 PM |
Water Meter | Ceri JC | Idle Banter | 14 | 07-03-07 09:36 AM |
speedo light gone, half of rev meter gone?? | huge | SV Talk, Tuning & Tweaking | 10 | 07-12-05 03:28 PM |
Resetting the ODO meter?? Help!!! | Runner Type R | SV Talk, Tuning & Tweaking | 3 | 20-02-05 10:24 PM |
