Ancillaries Post your own reviews, opinions and experiences on various other bits and bobs, such as rearsets, oil, engine bits.
Old 19-09-06, 09:22 AM   #1
H
Default Clutch been snapped off
Think I was reversed into, Clutch lever now hanging by cable only, I have a Y-Reg (2001) curvy. Can anyone advise what clutch leaver is needed for me to replace it with, best p-lace to get one (ebay etc), and how much) and is it an easy job ?
great return from holiday !
H
Old 20-09-06, 10:52 PM   #2
Heed
You'll either be looking at
This
or
This
depending on how old your bike is. There's loads of levers on eBay including a lot of coloured/carbon look ones. Take your pick. As for fitting one
Not my thing.
Old 20-09-06, 11:03 PM   #3
Razor
Levers are going for stupid money on ebay at the mo.
Would only take 10 minutes to swop.
OE levers are stronger than the pattern ones but pattern make good spares. I've been meaning to zip tie my spares to the inside of the sub frame.
Old 21-09-06, 07:40 AM   #4
fizzwheel
fizzwheel's Avatar
Liz bought a pair of pattern levers ( Front brake and clutch ) for her naked curvey SV
IIRC £22 from Demon Tweaks.
Old 21-09-06, 08:08 AM   #5
H
bought one off ebay for a tenner
now just got to fit it, is this as straight forward as it looks ?
Old 21-09-06, 08:36 AM   #6
Viney
Default Re: Clutch been snapped off
H
So have they snapped the lever mount? If so, then you will need to buy one of them. Try www.suzukispares.co.uk Fast mail order.
Old 21-09-06, 08:49 AM   #7
Razor
Pretty much. Release the tension in the cable, replace lever, re-adjust clutch tension.
If you're strong enough you can do it without all that but be careful of breaking a nail...
Need I say a haynes or workshop manual close at hand is a good idea
Old 11-03-07, 03:43 AM   #8
kcowgergmm
i broke the clutch cable adjuster next to the clutch handle when i was shifting hard at about 125mph and rode it back with out the use of my clutch has anyone else had this problem? yeah stoplight and stop signs are a @#$%^ thank god the two cops that i ran a stop sign in front of were not paying attention
Old 11-03-07, 10:58 AM   #9
squirrel_hunter
squirrel_hunter's Avatar
If the mounting points fubared you could always do the adjustable lever mod, see here.
As a side note the clutch leaver from a ZX10 wont fit
"A little enthusiastic?"
SH2 | 2MA | GROM | YSR
Brown Trousers. (snapped clutch cable) alex.j SV Talk, Tuning & Tweaking 20 01-09-06 09:35 PM
clutch ajduster snapped bobbydazzler SV Talk, Tuning & Tweaking 6 11-07-06 02:52 PM
Clutch Cable Snapped: MrMessy SV Talk, Tuning & Tweaking 2 16-01-06 09:18 AM
Clutch cable snapped on a 99 plate. Scoobs SV Talk, Tuning & Tweaking 13 13-05-05 10:28 AM
