Hi all.
When my pointy is on tickover, the display and lights flicker. When I blip the throttle they get brighter. Is this a sign of the battery dying as its only just recently started doing this. (or im a dumb ass and it normally did this, but i've only just noticed!) |
whats your idle speed set at?
Mine started doing this just before my starter reply died, the contact for the 30AMP fuse had coroded through.
1200 should be ok, my bike idles at 1000rpm and thats fine. i did have this with a cbr tho and adjusting the idle sorted it.
Cheers Kwak, i'll adjust it tomorrow and see if that solves things.
could be a number of things like Grinch said but this is my only experience of this.
Now I might be wrong, but I'm sure when my reg / rec was on its way out I had simialr symptoms to the ones you are getting.
Might be worth doing a search for a post by Sid Squid that explains how to check your charging circuit is working properly. Have you been having problems with starting or what seems like reluctance to start. Remember this could be a red herring, but I guess it wouldnt hurt to check ?
#9 |
Sounds about normal to me.
The bike will not be charging below a rpm level (5500rpm for curveys IIRC) so as the revs increase so will the strength of the lights as more current is being generated. If you are worried stick the battery on charge and stop leaving it on tick over. But seriously as Fizz said Sid Squid is the man (thanks again!). |
Neutral Light flicker | Grinch | SV Talk, Tuning & Tweaking | 2 | 08-04-09 03:29 PM |
Display lights not working | joff80 | SV Talk, Tuning & Tweaking | 3 | 27-09-08 01:32 PM |
No Tickover | aermacchi | SV Talk, Tuning & Tweaking | 3 | 14-04-08 10:56 AM |
lights flicker while on idle and when indicating | ricky | Bikes - Talk & Issues | 11 | 05-04-08 03:19 PM |
tickover pin | Hazzar | Stuff Wanted | 0 | 09-09-07 04:37 PM |
