Old 07-05-07, 06:23 PM   #1
Phantomtek
Default Hilf! :(
Hi, Me again.
The most recent problem has the following symptoms:
Speedo and Revmeter randomly fluctuating and falling and basically going abit mental,
Random bouts of misfiring, only slight misfiring but noticeable.
Any idea what it could be, I first noticed something weird the other day (It hasn't been rained on) where the revmeter flew up and back down when I switched the engine on, it never usually does this, and then odd moments when the speedo seemed to float around abit.
Any ideas?
Probably going to be expensive
Old 07-05-07, 06:36 PM   #2
Default Re: Hilf! :(
Probably electrical, I reckon... Check battery terminal contacts, and make sure the main fuse is seated right first of all, then it's all the usual tedious electrical troubleshoots.
Old 07-05-07, 06:38 PM   #3
squirrel_hunter
squirrel_hunter's Avatar
I have seen this on my bike a couple of times. The worst being just before the reg/rec went.
Check that the battery is connected securely and that your charging circuit is working. If that is not the answer then I would start looking and wires and connectors around the instrument panel, unless of course anyone else can suggest something...
"A little enthusiastic?"
SH2 | 2MA | GROM | YSR
Old 07-05-07, 07:17 PM   #4
Phantomtek
Cheers, will have a gander as soon as I find my damn allen keys!
Any other advice welcomed, I did actually think it was my reg rec, though the first instance of it happening was after I finished doing some wheelies so it could be a loose connection.
Old 07-05-07, 07:25 PM   #5
Phantomtek
I'm a silly *******, just checked the battery and found the live counterpart isnt screwed on properly!
Will screw it on and see if helps, should do!
Cheers guys.
