#11 |
Afternoon all.
I came across Never-Seez in the early eighties when us dispatch riders were trying to prevent our brakes seizing up. It differs considerably from normal copperslip, as it's somewhat thicker in consistency, & is a right old cocktail of things including Aluminium & Copper, & it has a melting point around 1100 degrees centigrade. I certainly wouldn't recommend using ordinary copperslip on caliper pistons, as most cheaper varieties are much more oily, & there is the possibility of the seals swelling if an excess of oil comes into contact with them. I have found that applying Never-seez to the pistons on top of the rubber lube prevents the rubber lube from being washed away, & also provides another layer of protection when it comes to preventing water entering the caliper & getting behind the seals. My mates XJ900 dispatch bike retired after 8 years & 215k miles. I had regularly cleaned & lubed the calipers 'my way'. It had never needed a caliper overhaul & the wheels still spun freely. There have also been countless others that I have serviced over many years...I rest my case M'lud! ![]() Cheers. |
#12 | |
All the best Jambo.
#13 | |
#14 |
Ok so summing up its fine to scrape the recess if other cleaning products don't work.
But can I just check, the red caliper grease should be applied all over both the piston seal and the dust seal? Also I was always told that a little brake fluid should also be applied to the recess IIRC, if this is correct, though not previously mentioned should this be used in conjunction with the grease or is the grease best on its own? |
#15 |
Morning all.
Yes it's fine to scrape the seal recesses, providing you don't get carried away. If you don't have a Dremel, get yourself a small brass brush of the type used for cleaning spark plugs, or indeed the type used for cleaning suede shoes. Being brass, & somewhat softer than the alloy the caliper is made from it'll remove the corrosion without scratching the alloy. Brake fluid should only be used as a lubricant if you have no rubber lube, there's no need for both, & yes, apply a thin layer of it all over the seal & the piston. Jambo you're right to question my use of 'copperslip' on caliper pistons. It is somewhat contrary to accepted practise, which is how most people who have been taught bike maintenance are instructed. All the tricks of the trade I use I have discovered & refined over the last 30+ years. I know this method works. Finally when cleaning caliper pistons in situ, a looped cable tie makes an excellent cleaning device as it's serrated on the inside. A short length of parcel banding can be used also. This is particularly useful on multi piston calipers where the clearance between the piston & the caliper body is too small for a cable tie. I also urge you guys to get hold of some silicone lubricant. 3 in 1 do an excellent variant which is available from Halfords & some B&Q stores. It has a multitude of uses, & is particularly good at softening the grime that builds up on caliper pistons. It's also very effective on cables, bodywork grommets, & under the rubbers on gearlever linkages. Cheers. Last edited by Spanner Man; 18-12-07 at 08:04 AM. |
I have messed up cleaning my calipers. | Stu | Bikes - Talk & Issues | 18 | 24-03-09 12:35 PM |
dumb cleaning question - brake calipers | skyline | SV Talk, Tuning & Tweaking | 6 | 27-10-08 01:21 PM |
Brake Calipers | Ash_sv650 | SV Talk, Tuning & Tweaking | 27 | 10-06-08 04:18 PM |
cleaning calipers -again! | jim@55 | SV Talk, Tuning & Tweaking | 1 | 11-03-06 03:25 PM |
Calipers | Hogzi | SV Talk, Tuning & Tweaking | 3 | 26-02-06 07:15 PM |
