Old 18-01-09, 11:20 AM   #11
Baph
Default Re: Indicator relays
Originally Posted by Bill.Cross View Post
I'm not absolutely certain about this but my guess is that the wattage rating of the relay just tells you how much power it is capable of passing. My thinking is that if you ask a 10 watt relay to pass 20 watts it will burn out but if you use a 20 watt relay for 10 watts you are just using a more costly and bigger peice of kit than you need but it will still work. It's just a switch.
I think.
Correct to a point. If you push too much through a relay, excessively, it will pop, which will mean that the NC circuit will remain closed, and the NO one will remain open, regardless of what voltage/current you supply the relay.
I thought about posting this before, but decided against it due to the thread being a very old one. 12v 10w relays are used in some scooters, particularly vespa's. Should anyone need one, they would be a good place to start looking.
Old 18-01-09, 06:59 PM   #12
Dave20046
Dave20046's Avatar
It's on the tray on top of the battery, and is bizarrely built into part of the starter lockout system, to use a standard relay you'll need to pull the relevant connectors out of the relay connector and arrange to connect them to your new flasher.
Cheers sid, I don't think I'll be using a standard relay - I'm swapping it out for a LED friendly relay.
Old 18-01-09, 10:35 PM   #13
Tiger 55
Thanks for the answers folks.
My own elegant solution was to bung the bike on Ebay and not mention that the indicators didn't work. I am ashamed.
Old 19-01-09, 01:42 AM   #14
Kilted Ginger
I was confused until I say the post dates, doh!
Old 19-01-09, 08:36 AM   #15
Dave20046
Dave20046's Avatar
Was just reading them not enough?
Low voltage relays DarrenSV650S Bikes - Talk & Issues 21 16-03-09 09:16 PM
Relays mattc SV Talk, Tuning & Tweaking 2 24-09-08 05:53 PM
LED Flash rate relays... DF! SV Talk, Tuning & Tweaking 4 17-09-08 06:47 AM
Indicator Q Davido Bikes - Talk & Issues 9 16-01-07 09:43 PM
indicator? kwak zzr Stuff Wanted 3 03-12-06 09:26 AM
