Old 08-10-08, 10:17 PM   #11
Default Re: Wd40
yayyy i got 5 litres of the stuff
Old 08-10-08, 10:18 PM   #12
Shellywoozle
Shellywoozle's Avatar
Default Re: Wd40
I don't need that much, maybe a little squirt now and again
Old 08-10-08, 10:42 PM   #13
tigersaw
tigersaw's Avatar
Default Re: Wd40
I use it for general cleaning, but I much prefer GT85 for lubrication, it smells so much nicer
Old 08-10-08, 11:16 PM   #14
Default Re: Wd40
No. Brake cleaner for cleaning. Proper oil or grease for where oil or grease is required.
It doesn't really work for proper cleaning, it doesn't work as a penetrant oil, and it's a naff lubricant. I use it very rarely, for cleaning stuff that carb or brake cleaner might eat.
Old 08-10-08, 11:23 PM   #15
appollo1
appollo1's Avatar
Default Re: Wd40
My mind is working overtime here Shelly!!!!
appollo1 is offline   Reply With Quote
Old 09-10-08, 07:22 AM   #16
454697819
Default Re: Wd40
agreed.. I use degreaser to shift old oil and grease... and white lube for bits that needs lubing , scotoiler for the chain and Heingericke's version of muck off for the rest...
oh and a high (ish) pressure hose...
Old 09-10-08, 09:15 AM   #17
Tiger 55
Default Re: Wd40
Love GT85. Motorbikes, bicycles, garden gate, door lock, letter box...
Basically I put it on everything except my cornflakes. And I'm working on that.
Old 09-10-08, 09:58 AM   #18
simesb
Default Re: Wd40
The WD40 stands for Water Displacement 40th Formula and it's lubricating properties are incidental. The weirdest use has to be on nightclub toilets - it dissolves cocaine apparently!
Old 09-10-08, 10:14 AM   #19
Jayneflakes
Jayneflakes's Avatar
Default Re: Wd40
It is amazing what you can learn on here.
Next time I have to clean cocaine off the coffee table after one of our little parties.
Any idea how to clean speed off of the cat?
Jayne you're a Pussy Magnet
Old 09-10-08, 10:45 AM   #20
Default Re: Wd40
i prefere to get lube off the back wheel with it
Wd40 parkinmj Idle Banter 18 16-02-09 05:57 PM
WD40 or 3-in-1? Tigerrrr....... Bikes - Talk & Issues 12 21-02-08 08:48 AM
WD40 On the chain? paulthewitt SV Talk, Tuning & Tweaking 7 09-09-06 11:02 AM
WD40 tip! shutdown SV Talk, Tuning & Tweaking 6 15-05-05 10:02 PM
WD40 jnadank SV Talk, Tuning & Tweaking 46 02-01-70 03:02 PM
