Old 05-01-10, 06:36 PM   #11
Bri w
Bri w's Avatar
Default Re: Another Boiler Problem!
Clicked on expecting a picture of the wife.
*checks to make sure wife isn't in the room*
Old 05-01-10, 06:55 PM   #12
Bluefish
gas valve may also be set incorrectly, it might not be modulating correctly, but thermisters is +1, and as said, your stat h/w on the boiler needs to be quite high if you are used to hot hot water, due to the weather, if the problem is with the shower then you will possibly need a new shower cartridge
Boiler Issues, again! Kinvig Idle Banter 8 20-12-09 03:36 PM
Ideal Boiler Help - Any Plumbers/Gas fitters? krhall Idle Banter 8 01-09-09 07:29 PM
Combi-boiler advice JediGoat Idle Banter 19 14-02-08 01:50 PM
Central Heating Boiler Reckless Rat Idle Banter 11 02-01-08 11:20 PM
gas boiler has gone steveg Idle Banter 14 06-10-07 10:46 AM
