Old 13-02-10, 05:10 PM   #11
xXBADGERXx
Default Re: Really hacked off with my Brakes
Yeah I've heard you're not supposed to use plumbers tape too, was air escaping round the nipples?
Originally yes , from the old nipples and the new ones , I wound PTFE tape onto the threads to reduce this and eliminate it from the equation , sounds like it could be a master cylinder issue then more expense on a bike I no longer care about or wish to spend any more money on .
Old 13-02-10, 05:11 PM   #12
fizzwheel
fizzwheel's Avatar
Well you've either got air in there still or, air is getting into the system somewhere.
As said above, master cylinder is the next place to look I woudl think...
Old 13-02-10, 05:13 PM   #13
xXBADGERXx
Fizz , it`s been bled 3 or 4 times and no sign of air , I did it the traditional way with pipe/pump/open nipple/squeeze lever/close nipple , Mityvac and have even syringed into and out of the system . Master Cylinder looks like the next culprit .
I was hoping to avoid all this by buying SV1000 calipers the other week and fitting them with the adaptors as the brakes are woeful anyway , and that debacle has turned out to be a waste of money as well and I am spending money on a braking sytem and getting nowhere ,which is aggravating me even more to the point where I nearly traded in for a Z750 the other day just to get rid .
Old 13-02-10, 05:16 PM   #14
jacksuzukisv650
thats all to much lol the only way fluid would leak through a bleed nipple is if it was rong nipple craked or the actual caliper was corroded or cracked
Old 13-02-10, 05:17 PM   #15
jacksuzukisv650
because your not going to get a gd solid brake until you stop al the leaks
Old 13-02-10, 05:18 PM   #16
xXBADGERXx
When the nipple is cracked open it can actually suck air past the threads and into the bottom of the bleed nipple and back out into the bleeding system , giving the appearance of air in the system , the giveaway is lots of teeny tiny air bubbles in rapid succession that look a bit frothy .
Old 13-02-10, 05:18 PM   #17
Dave20046
Dave20046's Avatar
It had new Stainless lines fitted 18 months ago when I fitted the ABM comfort kit and my mate made a comment that it was a bitch to bleed then and pumped the Fluid into it with a compressor . The pistons have a tiny bit of pitting on them but it is on the outer edge where it cannot go anywhere near the wiper seal ,
Fair enough, providing you've not got a puncture in your lines (think you'd notice) and the banjo bolts are all torqued up right (new copper crush washers?) i'd say it's safe to rule out the lines and pistons.
If the bleednipples were leaking then guess you had nothing to lose with the plumbers tape (i'd make sure they're not still leaking though - put water on them see if you see bubbles). Could be the mastercylinder that's the issue...
mClinder seals kit is around £15.
Edit - if you order a mastercylinder repair kit and it doesn't fit this is when alarm bells should ring! It's what happened to me, thought it was extremely unlikely to happen to anyone else but spotted (and pointed out) another forummer had the same issue. Infact there's an easy way to find out; the bore diamerter of the m'cylinder is stamped somewhere on it. e.g ' 5/8" '
Old 13-02-10, 05:19 PM   #18
xXBADGERXx
The nipples aren`t leaking as I cleaned everything down with contact cleaner and there was no residue afterwards over a period of 24 hours and the bike was in use as well . New copper washers were used and correct Torque was used on the Banjo bolts .
Old 13-02-10, 05:24 PM   #19
Dave20046
Dave20046's Avatar
Cool, I'd look to the master cylinder then - sounds like it's either that or one of those mistery faults that makes you want to slam your head into a wall.
You're not alone I'm going to have all this soon - just bought some shagged calipers
Old 13-02-10, 05:24 PM   #20
xXBADGERXx
Found this on eBay http://cgi.ebay.co.uk/MASTER-CYLINDE...item3efc4c613d
Mate , I am at the end of my rope with this bike , it`s my sole form of transport and I have been out on it all Winter , maintenance on my doorstep in the Snow and Ice and I just wish it would show me some friggin love back and just get back to being fun again
brakes rallyjon SV Talk, Tuning & Tweaking 10 11-05-09 09:59 PM
Me Brakes are Done in! I'm_a_Newbie SV Talk, Tuning & Tweaking 7 16-02-09 04:59 PM
Brakes! coombest Bikes - Talk & Issues 11 05-11-08 06:40 PM
Chip and Pin hacked... Grinch Idle Banter 6 13-08-08 06:32 PM
My Ebay has been hacked!! neio79 Idle Banter 19 16-04-08 11:13 AM
