Old 21-02-10, 12:48 AM   #11
allantheboss
Default Re: BMW S1000RR Titanium Valves at 14,200 RPM
Because I love you all so much, I got the link:
http://www.youtube.com/watch?v=CUFsQ5lTo6g
Old 21-02-10, 01:04 AM   #12
ThEGr33k
Thats pretty cool
Want it in super slow motion though so we can really see whats happening
Old 21-02-10, 01:09 AM   #13
squirrel_hunter
squirrel_hunter's Avatar
Originally Posted by embee View Post
It's a standard development check to determine valve rotation vs engine speed to ensure satisfactory rotation. You don't want excessive rotation as it can lead to seat wear but you do want some rotation to take place during the normal engine speed range to maintain clean seats and good sealing.
You quite often see rotation reversal too, the graph of valve rotation vs engine speed can be a bit like a hockey stick, dipping negative then going positive as speed increases.
The driving force behind valve rotation is the balance between spring helix angle and usually valve tip/follower friction. At low speed the tip friction will usually prevent rotation, as speed increases the inertia unloads the contact at full lift and rotation begins earlier in the lift cycle so rotation rates increase.
For lower speed engines it's common to introduce low friction elements into the system in order to promote rotation at low speeds, first is multigroove collets which don't grip the valve stem (often only on exhausts), for very low speed engines positive rotators can be used ("rotocoil").
Interestingly the short pivoted finger follower as in this case is usually the lowest inertia design so most suitable for very high speed valve gear.
Good game.
I noticed the rotation in the video also, was wondering if it was just a trick of the camera. So thanks for the explanation Embee and thanks for the link Pete.
"A little enthusiastic?"
SH2 | 2MA | GROM | YSR
Old 21-02-10, 02:31 PM   #14
Alpinestarhero
omg
kleenex
this is just fantastic, a great find. thanks pete! Embee, what is generaly considered to be a "low speed" engine?
Old 21-02-10, 05:59 PM   #15
Huge diesels, stationary engines, industrial stuff. Maybe big gennys, compressors etc.
Old 21-02-10, 06:44 PM   #16
Alpinestarhero
Cheers embee
Old 21-02-10, 07:12 PM   #17
Mej
Wife just walked in, I'm sat there smiling like a Cheshire cat and she's like....WTF?! "You're looking at some metal making noise?".......wimmin
lol
that vid is mad.
Old 21-02-10, 07:51 PM   #18
ThEGr33k
Here is some food for thought, the cams spin at half the speed of the crank! OMFG, I want to see how fast a piston is when the crank is at 14,200RPM!!!!!!!! Now that would be immense.
Old 21-02-10, 09:09 PM   #19
Move your hand up and down 230 times a second, with all that jailbait you're not shagging I bet that won't be difficult
Old 21-02-10, 09:12 PM   #20
Holdup
move your hand up and down 230 times a second, with all that jailbait you're not shagging i bet that won't be difficult
pmsl
Bmw s1000rr. Alpinestarhero Bikes - Talk & Issues 106 20-03-10 11:00 AM
S1000RR on Ice jans1971 Idle Banter 5 07-02-10 06:53 PM
valves - am i doing it right? Wideboy Bikes - Talk & Issues 9 18-10-08 03:33 PM
valves Wideboy Bikes - Talk & Issues 19 12-10-08 11:56 AM
valves sv650s_guy SV Talk, Tuning & Tweaking 6 10-03-06 10:25 PM
