Old 05-03-10, 04:06 PM   #11
Stu
Trinity
Stu's Avatar
Default Re: "Best" revs to change gear at?
Originally Posted by fastdruid View Post
10.5, preload the lever and use the limiter as a crude quickshifter.
Druid
Old 05-03-10, 04:23 PM   #12
Dave20046
Dave20046's Avatar
I change gear between 5 and 6k.
I don't believe in revving the knackers off my bikes. Many an arguement I have had about how harshly or not to ride a bike, but I like my bike purring not screaming
Don't think I've ever gone over 7k!
Your bike could be restricted and you wouldn't even know
Old 05-03-10, 04:33 PM   #13
Liam9188
i change at 9.5k when trying to get around quickly. After that, the engine starts to run out of steam.
As for not going above 7, well the SV has fairly relaxed piston acceleration figures, so I wouldn't expect you are saving much in terms of engine life by keeping the revs down. It wont help it enough to make a noticable difference shall we say. If you dont like high revving bikes, perhaps a harley or a buell is more your thing?
Old 05-03-10, 04:35 PM   #14
Amanda
Druid
Gobbledeegoop......
Old 05-03-10, 04:37 PM   #15
translation
"what are best revs to change at?"
"lots"
Old 05-03-10, 04:40 PM   #16
Alpinestarhero
Druid
racers
Old 05-03-10, 04:40 PM   #17
Huh? I do that on road...
Old 05-03-10, 04:44 PM   #18
allantheboss
What is "preloading the lever"?
Old 05-03-10, 04:45 PM   #19
You put a light upward pressure on the gear lever, then either momentarily roll off the throttle then pin it again, or keep it pinned right up to the limiter.
Old 05-03-10, 04:46 PM   #20
Rai86
+1 ... Way easier and is second nature now. Tend to **** up gear changes if i use the clutch
Scorpian Oval "Flame effect" exhaust damaged looking for a change! sv_rider1990 SV Talk, Tuning & Tweaking 5 23-06-08 07:13 AM
Indicator housing/shell & "gear lever"? ooger Stuff Wanted 14 13-11-07 02:21 PM
"Trick" Gear Lever Pointy svdemon For Sale - SV's and SV related items 7 04-11-07 02:12 PM
Makes a change from "Didn't see you mate" Red ones Idle Banter 4 06-02-06 07:54 PM
