Old 14-07-11, 11:41 AM   #11
NTECUK
NTECUK's Avatar
Default Re: Big bore kits
Read it . Makes the case for the sv 1000 or Falco even stronger
Old 14-07-11, 12:19 PM   #12
squirrel_hunter
squirrel_hunter's Avatar
Originally Posted by SV650Racer View Post
Yes we run 700cc bored out bikes and a 750cc bike which runs a 84mm bore with a stroker billet crank.
All of them have to run Carrillo rods, lightened and balanced crank, race generator and slipper clutch before we build them to keep them reliable.
We have not experienced any crank failures on the ones we run with the stock crank as we run the crank correctly balanced/lightened and with the race generators. IMHO its not the crank thats the issue its the weight of the flywheel weight as they are too heavy and it torque sheers the crank. The rods as stock are weak so we change those and the slipper clutch keeps stress off the motor under heavy downshifting and makes it nicer to ride anyway.
Most common issue we had was head bolts - you need stronger ones, rods and rod bolts. Other than that for a motor that is stressed beyond belief over stock they are strong if built correctly.
Referring specifically to 700cc big bores only, I was told that 700 was fine with the standard crank, rods and other internals. Can't remember about the head bolts however. So why do you recommend rods, lightened and balanced crank, race generator and slipper clutch? The intended use is on a road bike so a race generator would be an issue.
"A little enthusiastic?"
SH2 | 2MA | GROM | YSR
Old 14-07-11, 12:29 PM   #13
SV650Racer
All ours we build are race bikes and get the living daylights ragged out of them so stronger components are a must to keep reliable and run a season with no hassles.
If your running on the road then stock rods etc would be fine same with head bolts unless your running the compression we are on these bikes.
Old 14-07-11, 12:41 PM   #14
squirrel_hunter
Cool that tallies with the information I already have, thanks.
PM coming your way though...
Old 14-07-11, 12:43 PM   #15
NTECUK
NTECUK's Avatar
I'd like a noticeable increase in grunt from 4,000 rpm's. top speed is fine never go over 100mph .
don't really want to gear it down as it earns its keep as a commuter plodding up and down the A12.And if you have to start shuffling up/down the box to make progress it defeats the point of a v twin.
Old 14-07-11, 04:38 PM   #16
nille
I have some forged, very light CP 84mm pistons for sale,
if any one is interested. Will make an 694cc engine!
Brand new...
SV 650 Big Bore kits? liam_j_harris SV Talk, Tuning & Tweaking 107 16-05-08 06:04 AM
bore da! conwyrichie Idle Banter 33 06-04-08 02:24 PM
Who can fit a big bore kit? The Laughing Assassin SV Talk, Tuning & Tweaking 1 15-02-08 07:42 PM
Bore out for an SV650 danf1234 SV Talk, Tuning & Tweaking 6 22-07-07 06:42 PM
Big Bore Kit NSR Mike SV Talk, Tuning & Tweaking 17 06-06-05 08:50 PM
