#11 |
So it's a lot lighter now then as well
#12 | |
#13 |
![]() ![]() Cheers mate! You got your brakes sorted yet? |
#14 |
#15 | |
good enough for stoppies ![]() |
#16 | ||
breaded hoses might help ![]() |
#17 | |||
As for braided hoses you do not need them to stoppie the SV. I have a standard set up and have no problem doing them provided the tyre and brakes are up to temp, just ask Strechie, I even performed this little trick with him on the back! I would also not recommend attempting to learn them in this weather as you will need a dry road or you will just lock the front, and that ain't pretty. @Law: was waiting for someone to post that ![]() |
#18 | ||||
![]() i have tried a few times but wimp out a bit.as there is a lot of weight on the forks,headstock etc(what do you think about that?) |
#19 |
True that does put a lot of weight through the head stock, but it should be built to last.
Its like wheeling, done correctly and it won't add much wear to anything; for example headstock bearings, wheel bearings etc. But keep thumping it down and it will start to cause a problem. I'm not great at them, as I still can't do full on rolling stoppies, but I can still have some fun. Took my time to learn it, the first thing I did was learn how to lock and release the front wheel, which has saved me a couple of times (in situations other than stoppies) and progressed from there. Once you get the hang of it its easy, though as a word of warning landing an 11 o'clock hurts ![]() |
#20 |
.. cant do burn outs either
wheres valleyboy? | hovis | South & West Surfers | 27 | 14-03-07 08:45 AM |
valleyboy | kwak zzr | Idle Banter | 40 | 03-01-07 08:35 PM |
