Old 27-10-08, 07:20 PM   #21
Mr Speirs
Mr Speirs's Avatar
Default Re: Arrrrgggh. Bar End Screw Not Budging
Tried the mole grip thing. Used the rubber matting stuff and a maaaaaaahhosssive pair of grips and nowt. Would not budge.
Old 27-10-08, 07:21 PM   #22
Dangerous Dave
You tried the mole grips on the actual bar end weight???
Old 27-10-08, 07:25 PM   #23
Mr Speirs
Mr Speirs's Avatar
Yup.
Old 27-10-08, 07:28 PM   #24
Dangerous Dave
If you are trying to remove it from the Curvy in your avatar then you will get no where doing that, the screw and weight are not connected like they are on Pointys or nakeds. The bar end will simply pivot around and around....
You need to remove the screw.
Old 27-10-08, 07:31 PM   #25
Dangerous Dave
Curvy faired SV's bolt straight on to the end of the clip-on...
Pointy SV's and naked Curvy's use the rubber bung method, which you can pull out with mole grips....
Old 27-10-08, 07:33 PM   #26
Mr Speirs
Mr Speirs's Avatar
I realise that I need to remove the screw but thought if I could turn the bar end the same direction that the screw is removed that it would just loosen it a bit. When I say that nothing would budge I mean that even the bar end did not pivot around it stayed exactly where it is.
Old 27-10-08, 07:33 PM   #27
Dangerous Dave
Heres a good pic to explain....
Old 27-10-08, 07:34 PM   #28
Dangerous Dave
I realise that I need to remove the screw but thought if I could turn the bar end the same direction that the screw is removed.
No, the screw does not thread into the bar end it is pressed againt the clip-on by the screw.... The screw and bar end are not locked/attached to each other.
Old 27-10-08, 07:35 PM   #29
Sean_C
Drilling it out is the best option by the sounds of things. Drill the head off if you can, pull the bar end off, and use some grips to get the bolt out, or notch it and use a screw driver
Old 27-10-08, 07:35 PM   #30
Mr Speirs
Mr Speirs's Avatar
I already have the left bar end off so know how they are fixed to the bike just the right one is being an absolute bugger.
Got a screw in my tyre! bad-sv650 Bikes - Talk & Issues 10 04-02-08 06:16 PM
Screw ups The Hairy Hamish Pennine Massive 3 05-05-07 03:43 PM
Two up / Screw up John 675 SV Talk, Tuning & Tweaking 63 06-03-07 11:25 PM
tight screw hovis Bikes - Talk & Issues 13 04-01-07 01:45 PM
How do you screw up an oil change??? ls1bandit SV Talk, Tuning & Tweaking 29 19-09-06 10:55 AM
