Old 26-02-09, 02:03 PM   #21
Default Re: Brake Overhaul - picture heavy
Nah the reservoir is kinda sealed, but the membrane on top of it allows a change in volume.
Old 26-02-09, 02:08 PM   #22
Lucas
so drain the system first, then take brake off to clean, replace brake, refill system, got you
Old 26-02-09, 02:18 PM   #23
punyXpress
punyXpress's Avatar
What's behind the pistons will flood out, & that in the pipes will trickle out unless you pull the lever.
How do I know?
It's an age thing, so guess which I am.
Old 26-02-09, 02:18 PM   #24
No, pump pistons out, will get rid of most of the old fluid, then remove caliper. Catch the old stuff in a tin or with rags or something.
Old 26-02-09, 02:18 PM   #25
How do I know?
Indeed that will close transfer port and stop you losing fluid out of the reservoir.
Old 26-02-09, 02:20 PM   #26
punyXpress
punyXpress's Avatar
If one piston is nearly out & the other hasn't moved, hold the moving one with a narrow G clamp so the other is forced out.
Old 26-02-09, 02:25 PM   #27
[JP]
I've done this on several different bikes, good job to do, time comsuming but very rewarding…
tip..
hold one piston down with a clamp, pump the brake, let the other piston come out a bit (halfway), hold it with a clamp, release the other piston from clamp, pump the brakes till the piston comes out… then your other piston will be halfway out and easier to get out…
what I do is clean one by one though….but I take the caliper completely off the bike and use an air compressor to pop the pistons out, clamp x number of pistons down (will depend on bike) and put air in to pop the free one out..clean, replace seals, put back in…
then repeat this for the other pistons
Also by using this method of not allowing the piston to come out completely, you can clean the pistons a bit, using a tooth brush.
this helps to get rid of some of the road muc and release the pistons a bit…
(in case you can't be bothered to go through all the replacing seals, new fluid in, bleeding brakes stuff….)
Old 26-02-09, 02:31 PM   #28
Al_Sweetman
So I was right the first time around?
Aw man my head hurts now.
Old 27-02-09, 08:17 AM   #29
Dave20046
Dave20046's Avatar
Just to clarify what's the quickest easiest way to efectively clean up the brakes without faffing around draining the system?
Is there one.
Old 27-02-09, 09:12 AM   #30
timwilky
timwilky's Avatar
why are people so worried about draining the system. You need to change your fluid every couple of years, it is cheap, what is the problem?.
Brakes are what keep you alive, the fluid is an important part of the brake system, don't compromise. Do the job properly.
Use the on board extraction tool, as the pistons get pumped, a small g clamp to stop them popping until all are pushed out and then remove clamps, remove pistons, give them a polish. remove old seals, clean out the calipers properly, do not score anything, reassemble with a bit of red rubber grease on the new seals.
New fluid, bleed, and enjoy
Not Grumpy, opinionated.
Brake Overhaul Crash_Artist SV Talk, Tuning & Tweaking 3 18-02-09 07:44 PM
Bike Overhaul sv_rory SV Talk, Tuning & Tweaking 32 13-02-09 04:34 PM
Caliper overhaul. arcdef SV Talk, Tuning & Tweaking 114 31-01-09 04:57 PM
Front brake overhaul - how much? DarrenChay SV Talk, Tuning & Tweaking 7 03-01-09 09:12 PM
Brake overhaul Fuzz SV Talk, Tuning & Tweaking 4 13-03-06 11:51 AM
