Old 07-02-10, 11:11 PM   #21
hardhat_harry
Default Re: SV Curvy electrics question
I'll measure up tomorrow and let you know.
Do you know what size you need?
I can send you some cheap, you need to buy 10feet at a time and I am getting some soon.
I struggled to find it in UK too.
Old 07-02-10, 11:13 PM   #22
Stock SV front needs 6mm ID IIRC
Old 07-02-10, 11:18 PM   #23
hardhat_harry
Its anything but stock, ZX10 master cylinder to GSXR 4 pots but I only want to replace the resovoir.
Old 07-02-10, 11:25 PM   #24
Yeah you have that nipple on top of MC where hose from reservoir attaches, stock SV-S has similar nipple which takes 6mm tube.
You ridden it with ZX10 M/C, any good?
Old 07-02-10, 11:41 PM   #25
hardhat_harry
Not tried it yet but theoretically it should be very good. I am also running cast iron 320mm disks so it should stop on its nose.
Old 07-02-10, 11:48 PM   #26
hardhat_harry
The Verniers say its 10mm external 8mm internal
Old 08-02-10, 12:10 AM   #27
zadar
front is usually 6mm ID and rear 8mm ID. hose is very flexible and can stretch over easy.
They are actually standard, not metric, 1/4 and 5/16.
Old 08-02-10, 07:12 PM   #28
hardhat_harry
Jap4Performance have got a kit in to do the reservoir change bit pricey but bought it
Old 08-02-10, 07:50 PM   #29
Jesus H! £17 for bit of pipe? I will make some for a fiver...
Old 08-02-10, 10:10 PM   #30
hardhat_harry
I know but it supposed to be proper HRC.
I just want to get all the little jobs finished so I can actually use the thing.
Raised suspension linkage by 20mm today and sorted out the spacers on the front wheel (SRAD wheel in K1 forks).
Bearing question for Curvy hardhat_harry SV Talk, Tuning & Tweaking 54 18-12-09 08:41 PM
(guitar) electrics question thedonal Idle Banter 3 29-07-09 11:43 AM
Electrics completely gone haywire. curvy y2k jimmy SV Talk, Tuning & Tweaking 11 08-05-09 07:33 PM
headlight Question curvy Quiff Wichard SV Talk, Tuning & Tweaking 11 28-04-07 07:27 AM
Wee electrics question northwind SV Talk, Tuning & Tweaking 10 04-03-05 03:20 PM
