Old 23-04-10, 08:25 PM   #21
Drew Carey
Not Fizzwheel
Drew Carey's Avatar
Default Re: Removing rear wheel with no stand? Help
Cheers all.....thinking I will use Druids method, as dont have anything at hand to prop it on the side stand.
How best to get them on to axel stands? I presume place one on the right hand peg, then slowly jack up the left side until upright then slide the other one under?
"Feckinnnn Unluckkeeeeeeee"
Old 23-04-10, 08:28 PM   #22
Wideboy
Evel Knievel
Wideboy's Avatar
i jacked up the whole bike and lowered it onto the axle stands both at the same time, you may find that your axle stands wont go high enough aswell
05 DRZ400E
RIP hovis
Old 23-04-10, 08:33 PM   #23
Drew Carey
Not Fizzwheel
Drew Carey's Avatar
Ok, will look in the morning. Else it will be a case of using a car jack under the right peg and then hoping it doesn't fall over!!!!!
Old 23-04-10, 08:44 PM   #24
Wideboy
Evel Knievel
Wideboy's Avatar
can you not drop the swing arm onto the axle stands?
sorry if this has already been asked but I've only scanned the thread
05 DRZ400E
RIP hovis
Old 23-04-10, 08:49 PM   #25
Drew Carey
Not Fizzwheel
Drew Carey's Avatar
Yeah, can do, was thinking maybe wrapping the axel stands in cloth, placing one on right hand side, jack up the bike from the left, place axel stand under left hand side and hey presto.
Old 23-04-10, 08:53 PM   #26
Wideboy
Evel Knievel
Wideboy's Avatar
personally i would do that thing where you lift the rear off the ground on the side stand then get linseed to put the axle stand under the RH side then push the bike over and get linseed to run over to the left with the other stand
05 DRZ400E
RIP hovis
Old 23-04-10, 08:54 PM   #27
Drew Carey
Not Fizzwheel
Drew Carey's Avatar
Coolio.....job done. Will get it sorted tommorow.
Old 23-04-10, 08:55 PM   #28
lily
less of the running!
Old 23-04-10, 08:55 PM   #29
Holdup
Can recovery not just plug the hole to allow you to ride to a tyre fitters in the morning?
You dont want recovery to plug it because that will mean a new tyre will be needed
Old 23-04-10, 08:56 PM   #30
lily
AA have plugged a tyre before for drew, and it hasn't meant a new one!
Pointy stand for removing swing arm / shock etc Spokey SV Talk, Tuning & Tweaking 12 17-10-08 11:52 AM
Removing the rear wheel gilby104 SV Talk, Tuning & Tweaking 20 26-09-08 08:27 PM
what to do with the belt when removing the rear wheel on a buell kwak zzr Bikes - Talk & Issues 4 15-11-07 09:00 PM
What's the best stand to support the bike, while removing forks DarrenSV650S SV Talk, Tuning & Tweaking 23 30-10-07 05:51 PM
Storage: Side stand or rear paddock stand? Maudster SV Talk, Tuning & Tweaking 19 20-01-07 04:45 PM
