Old 20-08-10, 09:46 AM   #21
darkdreamsgal
Default Re: Rear Pre Load setting question.
I'm a noob too and really have very little idea about suspension beyond the basics, but I've been told that the heavier the load, the tighter the back suspension ought to be. I'm 9 & 1/2 stone and have found the most comfortable setting on my SV to be 1 - 2 clicks from the loosest setting (standard shock).
Some videos which explain suspension / sag (incl adjusting for different weights)...
http://www.youtube.com/watch?v=tEwX8TOn1YY
http://www.youtube.com/watch?v=v2agFfQC3wo
Jo
Old 20-08-10, 10:14 AM   #22
doogs
Im 17 stone and I've never adjusted the suspension on my SV (and this is stock suspension from new)
Old 20-08-10, 10:17 AM   #23
independentphoto
Great post Jo. That should help people understand a bit more about the different suspension elements.
Garry
Old 20-08-10, 10:40 AM   #24
Originally Posted by doogs View Post
Lets say the top box was mounted on a rack behind the rear wheel and loaded to the max (10kg). Wouldn't this make the front of the bike lighter? If so, does adjusting the rear suspension help at all?
Yes it can help, but it can't cure the effects completely.
Old 20-08-10, 11:43 AM   #25
barwel1992
to cure the afects further you would need a stiffer spring and i dont think you can change the sv rear shock spring
im running 5mm static sag and 32rider [gsxr 1k shock]
Old 20-08-10, 12:51 PM   #26
bengrrr
Changed mine to a Gixer 1000 as well (Thanks to Barwell for helping). its worth doing, however i've not got the pre-load spot on just yet. Doesn't feel quite right. (Dam site better that the original) i'll try the 5mm as we're about the same weight.
Old 20-08-10, 04:45 PM   #27
barwel1992
not sure how nmuch good it would do asmy bike is raised so linkage ratio and all that will be diferent to stock
Old 20-08-10, 06:52 PM   #28
darkdreamsgal
SV suspension http://www.youtube.com/watch?v=lUwtuRF4iXk
Old 21-08-10, 11:28 AM   #29
Yes, the overall load is higher, so to get you back to your previous point in the travel you'll need to raise the preload.
But that's not the problem, the problem with putting a large load into a topbox is that it shifts the centre of gravity backwards and upwards, so, even ifthe overall load is within the capabilities of the suspension to support, putting it there will result in lower load on the front tyre 'cos the weight is in a bad place.
Old 21-08-10, 07:48 PM   #30
Originally Posted by darkdreamsgal View Post
Preload =/= softer or harder
And 240lbs on stock shock? Er....
Rear pre-load and shock length question DavieSV SV Talk, Tuning & Tweaking 1 14-06-10 08:46 AM
adjusting pre load rear jimmyb96 SV Talk, Tuning & Tweaking 5 09-11-09 07:53 PM
Rear Axle Torque Setting K6 Hardened Rider SV Talk, Tuning & Tweaking 3 01-09-08 09:51 AM
Rear Shock Hydraulic Pre-load Adjusters Luckypants SV Talk, Tuning & Tweaking 5 31-01-07 05:02 PM
rear sproket torque setting matsv650s SV Talk, Tuning & Tweaking 4 03-02-05 01:37 PM
