Old 11-03-11, 08:08 AM   #21
mikerj
Default Re: Baffles....
Originally Posted by Stonesie View Post
I usually get 135 - 155 to the light on mine, once it was up near 180 after a very gentle rideout on crappy slippery roads (K6 pointy with end can)
Pretty much the same as me on a K5 with a slip on can, and I don't ride it particularly economically, although it's only ever used for longer journeys (60 mile round trip commute mainly).
OPs bike certainly sounds a bit poorly; does it get up to temperature ok?
Old 11-03-11, 01:04 PM   #22
irons
Default Re: Do removable baffles affect economy?
i get around 130 before the light on my commute but 80% of that is motorway
Old 11-03-11, 02:17 PM   #23
RavenWire
it seems to warm up alright. Whats the ideal temp for it to be running at?
Old 11-03-11, 02:25 PM   #24
Bluefish
80-90 is normal
Old 11-03-11, 02:40 PM   #25
Reeder
Mid 80's I think
Old 12-03-11, 04:00 AM   #26
monkey
Probalbly only if you get tugged and fined
Old 12-03-11, 10:20 AM   #27
If a car exhaust is faulty/nacked its surposed to burn more fuel so i surpose its the same with a bike, i tryed riding my gixer with the yoshi baffle in but within hours it was out again, i'll pay for the noise thanks
Old 12-03-11, 10:43 AM   #28
That's if the cat collapses inside or something and partially blocks it up, makes it rich.
Or air leaks can trick lambda sensor into dumping lots of fuel in.
On the bike it depends on lots of things, mostly the jetting/mapping and how that's set.
Old 12-03-11, 10:56 AM   #29
Webber
Heavy handed ill get 88 on a tank, but normally ill have about 140miles before fuel lights back on.
Old 12-03-11, 05:30 PM   #30
EssexDave
88 miles is from fill up to light coming on. Its mainly town riding but there is a bit of national. I don't really go above 7k revs because i get enough go at lower revs. I'll try being a bit gentler on the acceleration see if that helps. I use engine braking a fair bit and its pretty strong but i was led to believe its better of fuel than braking more
I know this is going to be silly, but how much fuel does it take you to fill up?
I've only ever once had less to a tank on a pointy than that, and that was really shifting.
I can get 160 to the light if you're on a nice run and get to carry speed rather than have to scrub it off.
Generally, I expect the light to come on about 120-135 if you're around town with the odd bit of a blast.
higher compression - how would it affect A/F? barwel1992 SV Talk, Tuning & Tweaking 16 22-02-11 12:17 PM
How does the new tax rate affect you? gettin2dizzy Idle Banter 46 08-04-08 05:43 AM
The Budget - how will it affect you the_lone_wolf Idle Banter 40 13-03-08 04:36 PM
Alarm - Will it affect my warranty? Defender SV Talk, Tuning & Tweaking 9 19-01-08 10:27 PM
