Old 01-08-06, 03:22 PM   #21
SV1000s
Originally Posted by The Basket
The SV can be quite wristy so they all do that, sir.
Rubbish, you havn't adjusted your levers, there is NOTHING wrong other then the fact the levers are set up wrong in the factory, undo the nut and drop them a little. Even if it is 'wristy' this has NOTHING to do with his hands going numb.
Yes it is...the chap may have poor circulation too but that is a side issue.
If you put a part of the body under abnormal pressure or funny angles then it will create some interesting results...a bit like stress positions...it will start to hurt...and cause numbness.
Yet another ****ing contest on this site.
You siad the SV is wristy, by that I thought you meant that it's hard on the wrists. If it is hard on the wrists then you need to alter the angle of the levers.
Also when riding your arms/wrists should be parallel to the ground, if the are not then your wrist will be kinked and yes, then you will get pain in your wrists.
If you look above then you will notice 2 things.
It's not the bike, it's the RIDER!
Sort your levers out and drop your elbows a little and it won't be 'wristy'.
Old 01-08-06, 03:33 PM   #22
"****ing contest". Hardly. Riding with your forearms horizontal is all very well on track, show me anyone who rides like that on the road...
Old 01-08-06, 03:34 PM   #23
The Basket
****ing contest? Merely a discussion based on my own understanding of what I know...
Wristy in the sense that the SV has a sporty seating arrangement which means that the body is leaned forward and so therefore putting weight on the wrist...maybe less than a ZX-7R but more than a Hornet.
Old 01-08-06, 03:37 PM   #24
SV1000s
Originally Posted by northwind
"p*ssing contest". Hardly. Riding with your forearms horizontal is all very well on track, show me anyone who rides like that on the road...
Me and thousands of others.
Old 01-08-06, 03:39 PM   #25
SV1000s
p*ssing contest? Merely a discussion based on my own understanding of what I know...
Ok, well you must be right then eh?
Try gripping the tank with you knees and not hanging on to the bars, I understand that this is the correct way to ride.
Old 01-08-06, 03:44 PM   #26
Warthog
Just to clarify, is it really pins and needles while going along, or a buzzing when stopped? Pins and needles is restricted bloodflow caused by hand position, clothing, squeezing etc, but what I tend to get is a buzzing/vibrating style pins and needles when I stop after my longish commute. (operators of pneumatic drills get the same I think) I think this is down to the bike vibrating at an annoying frequency when motorway riding, and can be stopped potentially by using different bars, weighted grips, or possibly changing the revs while riding. I still get these tingles though, not found a way to stop them.
Old 01-08-06, 03:51 PM   #27
To get those horizontal over distance, say goodbye to your back
Old 01-08-06, 03:55 PM   #28
SV1000s
I'm 6'4" and manage ok.
Hey, who cares I don't suffer from bad wrists or a bad back.
Old 01-08-06, 03:57 PM   #29
Whatever
Old 01-08-06, 04:06 PM   #30
SV1000s
Whatever
You're very touchy aren't you?
Are you the site big shot with all those post?
Maybe your the site know all there is to know?
Cramping and pins/ needles Specialone Bikes - Talk & Issues 27 06-05-09 12:17 AM
Pins and Needles! COLZO Idle Banter 13 08-01-09 08:08 AM
Adjustable needles mwr2452 SV Talk, Tuning & Tweaking 9 07-07-07 08:05 PM
Adjusting carb needles Fuzz SV Talk, Tuning & Tweaking 16 05-09-05 08:15 AM
Shim the Carbs Needles TSM SV Talk, Tuning & Tweaking 3 25-07-05 11:26 AM
