Old 14-02-10, 06:54 PM   #41
Stu
Trinity
Stu's Avatar
Default Re: Really hacked off with my Brakes
Oh and a certain member messaged me with some drunken sh1te about giving people the wrong impression about SV650`s and I should not be bad mouthing my brakes
(not that I'm taking it seriously but) I think anyone that knows you, knows that you've enjoyed enough miles on your SV for you to think that it's great bike for what it is.
and maybe I should sit down and have a talk with them ....
I might try that, do you think it will work? I was just trying to clean up my brakes but I've got a seal popping out so can't put them back together without doing a proper service
.... I came here to seek advice on something that is dangerous to my operation of my bike and if I feel fit to come on here and seek advice I will do .
Please go right ahead
Old 14-02-10, 07:45 PM   #42
Dave20046
Dave20046's Avatar
Oh and a certain member messaged me with some drunken sh1te about giving people the wrong impression about SV650`s and I should not be bad mouthing my brakes and maybe I should sit down and have a talk with them ........ I came here to seek advice on something that is dangerous to my operation of my bike and if I feel fit to come on here and seek advice I will do .
LOL! were they being serious!?
...Hang on I hope it wasn't me
Feel your pain badger I'm currently trying to service some knackered gsxr calipers; one doesn't even have seals in so no pressure to force the pistons out with and the other does but they're shagged and I'm trying to force them out with a knackered old rd350 mastercylinder that I think is leaking and the cherry on the cake is the bolts to split the calipers are warped to feck. Good old ebay lucky dips...
(sorry for the derail just wanted to vent in a light hearted manner - nothing against gsxr's )
Old 14-02-10, 07:53 PM   #43
use a tyre compressor over the banjo hole. remember to aim at a bucket of water or inside said bucket. also if you put a strip of ply wood in the middle of the caliper when you are pumping out the pistons then the pistons wont come fully out and you can ease then out after you split the caliper.
Old 14-02-10, 07:59 PM   #44
beabert
Yes they are Hel Lines , the upright over the reservoir trick sounds like a good idea , I would be interested in trying another Master Cylinder alternative instead of a rebuild kit .
The system does bite properly and can haul the bike down from speed , just the lever travel itself is 50% before any bite occurs . I chatted with my mate who helped me fit these originally and he remembered that we could only get this done properly with a compressor , I am not sure if we drew air through the sytem using his compressor as a Vacuum with some old bleeding kits , or we had a jar and pumped it into the system . Gonna give that a whirl first and see what happens . Either way it`s a right sunuvabitch to bleed and something has not been right from the moment we fitted these HEL lines .
LOL at someone PMing you!
To mr drunken man, the sv650 IS a poorly built bike, fell free to PM me lol.
Old 14-02-10, 08:21 PM   #45
punyXpress
punyXpress's Avatar
xXBADGERXx - you say once it bites it's good but there's half a lever of movement before owt happens.
That would point to air in system NOT being the main problem or it would be VERY spongey once the half movement was used up?
Now: Street Triple R
Old 14-02-10, 08:49 PM   #46
Poor Badger, I'm sure Mr nasty PM person, that once his POS brakes are working right again he will love his SV
Old 14-02-10, 09:48 PM   #47
xXBADGERXx
Out of all of this I can actually return a tip to those with stuck pistons . Get a cable tie and wrap it around the piston and zip it up tight , you can then use a pipe wrench or Mole Grip to latch onto the Piston and try to rotate it out , if it`s stuck then spray a dab of ACF50 or Plusgas in there . It should come out with a few rotations . Once out you can remove the cable tie and there will be no damage to the piston where the seals go . There may be a little damage on the hollowed part which can be removed with a file but at least it won`t be a part that touches any seals .
Old 14-02-10, 10:51 PM   #48
Kirkybhoy
Kirkybhoy's Avatar
Have you replaced all the fluid ? seem to remember that after a while it absorbs water and reduces efficiency ? Just a thought.
The World Is Full Of Kings & Queens Who Blind Your Eyes & Steal Your Dreams..
Kirkybhoy is offline   Reply With Quote
Old 14-02-10, 11:08 PM   #49
xXBADGERXx
About half a litre of fluid has gone through this system over the last week with the various attempts . I used to buy tiny bottles when I bled my other bikes , since owning the SV I tend to buy it in bulk
Old 15-02-10, 06:16 PM   #50
Dave20046
Dave20046's Avatar
me too - got a 4litre tub on the go at the mo.
brakes rallyjon SV Talk, Tuning & Tweaking 10 11-05-09 09:59 PM
Me Brakes are Done in! I'm_a_Newbie SV Talk, Tuning & Tweaking 7 16-02-09 04:59 PM
Brakes! coombest Bikes - Talk & Issues 11 05-11-08 06:40 PM
Chip and Pin hacked... Grinch Idle Banter 6 13-08-08 06:32 PM
My Ebay has been hacked!! neio79 Idle Banter 19 16-04-08 11:13 AM
