#61 | |
#62 |
I knew what you meant Ralph . Anyway , took the cap off the reservoir , removed the Rubber Diaphragm and white washer and put the cap back on half a turn . Squeezed a bubble out of the black tube whilst I was there . Gave the lever a few rapid pumps and then jammed it against the bar with a cable tie , will get up early and give the system a quick crack to see if anything occurs .
#63 | |
#64 |
Just doing mine at the moment, so this is straight from one end of the horse's digestive tract.
Calipers & lines on, reservoir 2/3 full. Lever back to the bars. Couple of SMALL bubbles in the res. Since no pressure at this stage, not a lot of point playing with the bleeding end. After the above couple of bubbles, thought getting as much air as poss out of the top would help so applying a light but rapid flagellating rhythm to the lever got quite a bit more air out the top, which is the way it wants to travel. I used my hand for this, but your lady friend's SECOND BEST vibrator might be more fun ( don't use BEST or it wont be lack of brakes that kill you ! ) The lever was now fairly firm & just under half way back to the bar. Only at this stage did I try the bleeders & a very small amount of air came out. The lever was firmer and just about to go out & have another go to get it just right. Moral of this tale: Get the air out of the lines first 'cos until you do you are pi$$ing in the wind pushing the bubbles up & down the pipes. xBADGERXx - what master cylinder are you using, naked or S ? Have a good S you can borrow if any help ( I'll do anything to get into your shovel society )
Was: K2 naked in rapid yellow ![]() Now: Street Triple R |
#65 |
could reverse bleed it...
i.e get one of the metal oil cannister things, fill with brake fluid, take lid of resevoir attach a pipe to oil cannister then to bleed nipple... trying to have fluid at the tip of the pipe first to stop any more air being pushed up... and start pumping the oil cannister and watch the air bubbles at the resevoir... not sure if this has been already suggested. |
#66 |
I'd be careful about leaving the reservoir cap undone. Brake fluid is hygroscopic and absorbs moisture form the air. At this time of year there's a lot of it about too!
brakes | rallyjon | SV Talk, Tuning & Tweaking | 10 | 11-05-09 09:59 PM |
Me Brakes are Done in! | I'm_a_Newbie | SV Talk, Tuning & Tweaking | 7 | 16-02-09 04:59 PM |
Brakes! | coombest | Bikes - Talk & Issues | 11 | 05-11-08 06:40 PM |
Chip and Pin hacked... | Grinch | Idle Banter | 6 | 13-08-08 06:32 PM |
My Ebay has been hacked!! | neio79 | Idle Banter | 19 | 16-04-08 11:13 AM |
