Old 20-06-09, 09:43 AM   #1
PaulSV
Default K & N Filter
just a quick one, can I change standard air filter for a K & N, I'm using a blue flame end can with baffle in, or will I need a Power Commander
Old 20-06-09, 01:01 PM   #2
rowdy
rowdy's Avatar
Default Re: K & N Filter
Pointy or curvy?
Element or complete air filter?
Old 20-06-09, 04:09 PM   #3
PaulSV
K7 (pointy) just the air filter element
Old 20-06-09, 05:57 PM   #4
sv650nutter149
using just the filter and can is ok....you will get some slight pops on the over run which sounds nice but up to u mate
Old 21-06-09, 10:07 AM   #5
zigrat
Did the same to mine - seems to pull slightly better thru the revs + the pops sound nice
Old 21-06-09, 04:57 PM   #6
panosm
what about fitting it in a curvy with a can?
Old 24-06-09, 10:16 AM   #7
PaulSV
Question Re: K & N Filter
How about chopping off the snorkel too (doesn't look like it will come off any other way, or will it)?
Old 24-06-09, 01:01 PM   #8
The Guru
Pull it. It does come off. I took mine off and put SV1000 one on.
Old 24-06-09, 01:56 PM   #9
rowdy
rowdy's Avatar
To be honest don't expect much noticable gain with the k&n, bmc are supposed to be better although I wouldn't know, have only used the k&n.
panosm, same as just put it in and go, either case power commanders aren't much benefit if any for what £200 or so. Better and cheaper to take it to a rolling road and get it set up that way if you so wish.
Air filter suzuki badboy SV Talk, Tuning & Tweaking 11 14-05-09 07:05 PM
K&n Air Filter lancasterlad Ancillaries 12 23-11-07 04:24 AM
K&N Filter Phantomtek Stuff Wanted 1 25-04-07 05:48 PM
oil, filter and air filter change doe SV Talk, Tuning & Tweaking 10 17-04-06 01:29 PM
To filter or not to Filter.....are you feeling lucky? Magoo Bikes - Talk & Issues 40 02-12-04 05:17 PM
