As I’m splitting the cases to rebuild my engine and having split everything down I’m starting to think about putting it all back together. Thus I need gaskets.
Quick look over at Wemoto and a full gasket set comes in at £120. Let’s just say it was lucky I was sitting down. So suggestions please, where is cheaper etc? And are pattern ones like this acceptable or should I stick with the Suzuki items? I already have new OEM exhaust gaskets in the garage should I just get the gaskets I need as some in that kit I haven’t touched in the engine or will it be just as expensive. I think it’s just the head gaskets, the covers (valve and sides) and cam adjusters that I will need. Oh and the water pump (stupid bible) and generator o-rings. |
I'd go with OEM or decent aftermarket for head gaskets just due to the grief if they go. As for the others well it depends, some can be reused with a smear of sealant, some you can make yourself out of gasket paper.
As for O-rings, loads of the ones the manual say always replace I risk and haven't had them leak on me. Druid
'00 SV700S - '94 RVF400R - '97 RVF400R - '88 VFR750F Last edited by fastdruid; 16-09-09 at 02:30 PM. |
Don't split the water pump.
Alternator will be fine. Get good head gasket, make base gasket out of gasket paper. Output shaft seals and stuff should be obtainable for pennies from a bearing factor.
Cereal Box Gaskets | DarrenSV650S | Bikes - Talk & Issues | 7 | 22-04-09 09:53 PM |
Gaskets | Alpinestarhero | Bikes - Talk & Issues | 4 | 17-03-09 07:49 PM |
Gaskets | Jay12329 | Stuff Wanted | 1 | 15-02-09 07:55 PM |
Where do i buy gaskets? | New Leaf | SV Talk, Tuning & Tweaking | 7 | 17-04-07 06:57 PM |
Clutch Gaskets? | kellie000 | SV Talk, Tuning & Tweaking | 3 | 05-01-07 11:15 AM |
