Old 16-11-10, 08:19 PM   #1
Spider
Default Pointy headstock bearing dimensions, supplier?
any1 know of a good supplier or at least the size specs on a K6 naked, main dealer wants about 65 quid cheers
Old 16-11-10, 08:29 PM   #2
Default Re: headstock bearings
http://simplybearings.co.uk/shop/p43...duct_info.html
remember to get a new bottom seal from suzuki.
Old 16-11-10, 08:30 PM   #3
Get the bearing dimensions from Wemoto and then go to your local bearing factor and order them from there
http://www.wemoto.com/bikes/Suzuki/SV_650_K6/06/
Old 17-11-10, 07:12 AM   #4
Spanner Man
Default Re: Pointy headstock bearing dimensions, supplier?
Good morning all.
The bearings are 55mm od x30 bore x17mm deep. If you want the genuine caged ball race type. Go to a Honda dealer & order 2 of part number; 91016-KT8-005. These are the same Koyo bearings that Suzuki use, apart from they have a metal cage for the balls as opposed to a plastic one. They're around £25 each including VAT.
A bottom seal from Suzuki is around £13, Again use a Honda one, part number; 53214-371-010. It's around £7 inc VAT.
If you want to go for the Taper roller option. Avoid the majority of mail order made in India/China/Gawd knows where rubbish! A good bearing factor should be able to supply you with Koyo bearings. These outlast just about all the other makes on the market by quite a margin. The part numbers you need are; 32006JR for the top, & 32006JRRS for the bottom. The bottom bearing has a built in seal. they should be around £30 inc VAT for the pair. If they try charging you more B & C Express have them listed at around £25 inc VAT for the pair, + Postage. B & C's part numbers are BGS008 for the bottom bearing & BGS066 for the top one.
I've just noticed that you're in Middlesex. As am I. I probably have what you need on the shelf. Give me a shout if I can help.
Cheers.
Spanner Man
Old 17-11-10, 09:04 AM   #5
danf1234
Wow that's what I called an informed reply.
Old 17-11-10, 09:53 AM   #6
Spanner Man
Makes me think I've been doing this for way too long. Especially considering that I managed to quote most of the part numbers from memory! AAAARRGGHHH!
Spanner Man
Old 17-11-10, 10:24 AM   #7
Either qualifies you as a guru or a geek
Old 17-11-10, 03:32 PM   #8
the ones i posted a link to came in a Koyo box. their service is superb.
Old 17-11-10, 06:27 PM   #9
Spider
Spanner man i think i`ve just fallen in luv with u!! in a very blokey, completely hetro type of way
Old 17-11-10, 07:42 PM   #10
Slight hijack
Whats the part code for the curvy bearings, same set-up?
Old Headstock Bearing Races Needed Todge Stuff Wanted 7 19-02-10 11:12 PM
Headstock bearing play boot Bikes - Talk & Issues 6 20-10-09 01:30 PM
Headstock bearing/fork knock swinging_simian SV Talk, Tuning & Tweaking 6 21-08-08 08:44 AM
pointy tail light dimensions yankeedoodle Bikes - Talk & Issues 0 12-08-08 02:58 PM
Pointy Link Pipe Dimensions anyone? Spikenipple SV Talk, Tuning & Tweaking 3 05-06-08 12:42 PM
