Old 08-02-11, 08:44 PM   #1
muzikill
muzikill's Avatar
Default K3 Engine fix -case split
So im supposed to use one of these? - eh its over 100 quid! - the haynes book of lies says use a special clamp but doesnt really show how its made...
here is the official tool ...
I was wondering since all this does push on the rear chain side cam shaft to to split them could i not use a large c-clamp with a bit of wood on the fixed end to protect the inside of the cylinder?
Otherwise it's back to the drawing board, unless some kind soul in the central scotland area can lend a hand thats done it before!
Old 08-02-11, 09:16 PM   #2
Default Re: K3 Engine fix -case split
See if you can split it normally first.
Old 08-02-11, 09:26 PM   #3
muzikill
muzikill's Avatar
Heh, i know i've had so great advice from you mate, whats the normal way to split it? - ive tried to look around the net for some pics to see but to no avail!
Old 08-02-11, 09:30 PM   #4
There's some tabs stuck out of the cases near the split line IIRC. Knock them with a bit of wood or nylon hammer or something.
Cases need to split evenly because of dowels, make sure you get all the bolts as some are inside and not immediately apparent.
Old 08-02-11, 10:11 PM   #5
Using a soft hammer - preferably rubber and light - after removing all the bolts tap around the joint firmly first, this helps to unstick the cases a a bit.
Then gently use the tabs/pry points around the cases to bring them apart. As Chris says make sure they come apart as evenly and parallel as possible.
Under no circumstances lever between the case halves - they're very easily damaged and won't seal when you bolt them back up.
Old 08-02-11, 11:18 PM   #6
squirrel_hunter
squirrel_hunter's Avatar
I did mine as described by Mr Yorkie and Mr Squid.
"A little enthusiastic?"
SH2 | 2MA | GROM | YSR
Old 09-02-11, 02:22 AM   #7
zadar
I have split couple hundred of them without that tool. Soft hammer works fine.
Old 09-02-11, 08:49 AM   #8
muzikill
muzikill's Avatar
Ok , ta once again for the advice i will post in here to let you know how i get on.
Old 13-02-11, 04:11 PM   #9
muzikill
muzikill's Avatar
timberrrrrrrrrrr!
case looks fine, no bearing damage either! - making sure i havent lost any washers, o-rings and making notes on what i should REALLY replace (not what the manuals say)
Thanks so far!
Engine split advice - what special tools? muzikill Stuff Wanted 2 11-07-10 09:07 PM
Engine case paint? beabert SV Talk, Tuning & Tweaking 10 14-01-10 05:51 PM
Changing an engine case? Rich Bikes - Talk & Issues 5 02-09-09 08:23 PM
Crash.NET - 125: Haojue split with engine designer Jan Witteveen. NewsBot News 0 01-06-09 02:50 PM
snapped engine case bolt ben650 SV Talk, Tuning & Tweaking 15 21-11-05 07:59 PM
