Old 21-02-11, 09:19 PM   #1
the_lone_wolf
Captain Awesome
the_lone_wolf's Avatar
Default FTP client hangs while connecting socket
I know there's some IT guys on here, having something of a mare trying to use FTP to connect to my hosting account
It occasionally works, I can access the root directory and sometimes even navigate to the first or second sub directory level, but within a few movements it hangs for a minute or two and throws the following error in the log:
Code:
227 Entering Passive Mode ([IP],198,45)
LIST -al
Connect socket #988 to [IP], port [Random port between 50000 and 51000]...
Server failed to connect data port
Error loading directory...
[...] <-- My additions...
Ports 20, 21, 22 and 50,000 to 51,000 are allowed in/out in my router settings and the router logs suggest it isn't stopping transmission
Any ideas? I'm close to pulling teeth here not being able to get my site moving forward...
Edit to add, Both Filezilla and CoreFTP behave the same way...
(•_•)
( •_•)>⌐■-■
(⌐■_■)
Deal with it...
Old 21-02-11, 09:34 PM   #2
beabert
Default Re: FTP client hangs while connecting socket
You tried using internet explorer? using page, open ftp in windows explorer.
Old 21-02-11, 09:41 PM   #3
the_lone_wolf
Captain Awesome
I hadn't, but it fails
"The operation timed out"
(•_•)
( •_•)>⌐■-■
(⌐■_■)
Deal with it...
Old 21-02-11, 09:47 PM   #4
squirrel_hunter
squirrel_hunter's Avatar
Have you tried turning it off and then on?
"A little enthusiastic?"
SH2 | 2MA | GROM | YSR
Old 21-02-11, 09:53 PM   #5
Terah
Can you up the debug settings in FileZilla (Edit --> Settings --> Debug) and post a log?
Old 21-02-11, 09:54 PM   #6
beabert
Have you tried from a different network and/or PC? Its often the quickest way to see if its your problem or theres that way.
Old 21-02-11, 10:02 PM   #7
the_lone_wolf
Captain Awesome
Code:
Status:	Resolving address of [MY URL]
Status:	Connecting to [My IP]:21...
Status:	Connection established, waiting for welcome message...
Trace:	CFtpControlSocket::OnReceive()
Response:	220---------- Welcome to Pure-FTPd [privsep] [TLS] ----------
Response:	220-You are user number 44 of 500 allowed.
Response:	220-Local time is now 22:56. Server port: 21.
Response:	220-This is a private system - No anonymous login
Response:	220 You will be disconnected after 3 minutes of inactivity.
Trace:	CFtpControlSocket::SendNextCommand()
Command:	USER [REDACTED]
Response:	331 User [REDACTED] OK. Password required
Command:	PASS **************
Response:	230-User [REDACTED] has group access to:  inetuser
Response:	230 OK. Current restricted directory is /
Command:	SYST
Response:	215 UNIX Type: L8
Command:	FEAT
Response:	211-Extensions supported:
Response:	 EPRT
Response:	 IDLE
Response:	 MDTM
Response:	 SIZE
Response:	 REST STREAM
Response:	 MLST type*;size*;sizd*;modify*;UNIX.mode*;UNIX.uid*;UNIX.gid*;unique*;
Response:	 MLSD
Response:	 TVFS
Response:	 ESTP
Response:	 PASV
Response:	 EPSV
Response:	 SPSV
Response:	 ESTA
Response:	 AUTH TLS
Response:	 PBSZ
Response:	 PROT
Response:	211 End.
Status:	Connected
Trace:	CFtpControlSocket::ResetOperation(0)
Trace:	CControlSocket::ResetOperation(0)
Trace:	CFileZillaEnginePrivate::ResetOperation(0)
Status:	Retrieving directory listing...
Trace:	CFtpControlSocket::ChangeDirSend()
Command:	PWD
Response:	257 "/" is your current location
Trace:	CFtpControlSocket::ParseSubcommandResult(0)
Trace:	CFtpControlSocket::ListSubcommandResult()
Trace:	  state = 1
Trace:	CFtpControlSocket::TransferSend()
Trace:	  state = 1
Command:	TYPE I
Response:	200 TYPE is now 8-bit binary
Trace:	CFtpControlSocket::TransferParseResponse()
Trace:	  code = 2
Trace:	  state = 1
Trace:	  state = 2
Command:	PASV
Response:	227 Entering Passive Mode ([XXX],[XXX],[XXX],[XXX],196,71)
Trace:	  code = 2
Trace:	  state = 2
Trace:	  state = 4
Command:	MLSD
Trace:	CTransferSocket::OnConnect
Trace:	CTransferSocket::OnReceive(), m_transferMode=0
Trace:	CTransferSocket::OnClose(0)
Trace:	CTransferSocket::TransferEnd(1)
Trace:	CFtpControlSocket::TransferEnd()
Error:	Connection timed out
Trace:	CControlSocket::DoClose(2050)
Trace:	CFtpControlSocket::ResetOperation(2114)
Trace:	CControlSocket::ResetOperation(2114)
Error:	Failed to retrieve directory listing
Trace:	CFileZillaEnginePrivate::ResetOperation(2114)
Same as before, that's a fresh start of Filezilla followed immediately by asking it to connect through the site manager
Anything in [...] is my removal of personal info
Can't use another network as all the neighbours have secured theirs, but it behaves in exactly the same manner on my Desktop and Notebook
(•_•)
( •_•)>⌐■-■
(⌐■_■)
Deal with it...
Old 21-02-11, 10:22 PM   #8
Terah
OK - least likely but you can easily rule out server issues by checking your settings at http://ftptest.net
Client machine - still not too likely as you're getting the same on different machines, but: are you running firewall software on client machines? what is it? and have you tried disabling?
Router - what model router is it? and have you been able to ftp to any other site
Old 21-02-11, 10:28 PM   #9
the_lone_wolf
Captain Awesome
FTP test reports everything is OK
No firewall on either machine (I use windows firewall when on public networks, disabled at home as the router has one)
Router is Netgear DG834G - Don't have another FTP site to try
My suspicions land at the router, but short of opening all the ports I can seem to find mentioned I' not sure what else it could be
Might be ISP level I suppose but I'd have thought FTP was fairly common??
(•_•)
( •_•)>⌐■-■
(⌐■_■)
Deal with it...
Old 21-02-11, 10:43 PM   #10
hongman
PM me tomorrow afternoon if it still isn't sorted I'll set you up an FTP account to try (will be driving most morning).
Has it always done this or only recently?
You missed one user redaction btw
F'ed over by a client. Moojuicepez Idle Banter 21 09-02-10 01:03 AM
Problem client Ed Idle Banter 35 16-11-09 09:19 PM
Client gone bust Ed Idle Banter 22 10-06-08 09:23 AM
Geek opinion wanted, please: Thunderbird (mail client) Filipe M. Idle Banter 6 08-08-06 05:56 PM
New client - tips on client care required Ed Idle Banter 3 14-02-06 04:15 PM
