Old 23-09-11, 02:24 PM   #1
_Stretchie_
Large Member
_Stretchie_'s Avatar
Default Service manual download for a Focus 1.8 diesel?
Anyone know where I can download a service manual for a 2002 Ford Focus that covers the 1.8 diesel?
Cheers if you do. I can normally find a manual with a bit of googling but the only thing I have found after a lot of searching is a 400mb TIS file that I downloaded but it will not install.
How to amuze an idiot:
Look right-> <-Look Left
Old 23-09-11, 06:02 PM   #2
squirrel_hunter
squirrel_hunter's Avatar
Default Re: Service manual download for a Focus 1.8 diesel?
All I know is the plugs need changing every 20,000 miles.
Best of luck...
"A little enthusiastic?"
SH2 | 2MA | GROM | YSR
Old 24-09-11, 08:36 AM   #3
_Stretchie_
Large Member
Fool
Old 24-09-11, 09:05 AM   #4
Dan
http://www.etis.ford.com/fordservice...54988.dulv0676
HTH
Best of luck...
Old 24-09-11, 12:43 PM   #5
Supervox
No more Mr Nice Guy
Supervox's Avatar
Can't help with a download I'm afraid
But if you have a specific problem send me the details & I'll ask my Brother-in-law who's a Ford mechanic & who looks after our 1.8 diesel.
Never argue with an idiot - he'll drag you down to his level and then beat you with experience
Supervox is offline   Reply With Quote
Old 25-09-11, 01:43 AM   #6
_Stretchie_
Large Member
Thanks Andrew butnot after the service schedule. Someone at work has a noise that has started recently, always sounds, not just when warm/cold or under load. Had a listen and it's coming from the auxiliary belt.
Sounds like a pully coming loose, just wanted to know what to remove to get to them and which is which.
Old 25-09-11, 08:04 AM   #7
What mileage in on the Motor?
The 2.0l ford diesels do need the aux belts done at around 70k and the pulley wheels and tensioners aren't the best.
Old 25-09-11, 09:29 AM   #8
_Stretchie_
Large Member
Funnily enough it's on 70k. I've read that the air con pump come loose and needs the mounting bolts retightening.
Was going to get a new belt for him and see if it that needed tightening and if any of the pulleys were loose, then send him to the garage if it was anything else.
Cheers mate
Old 25-09-11, 09:45 AM   #9
I'll check with my mate what the aux belt change consisted of
Old 25-09-11, 09:56 AM   #10
_Stretchie_
Large Member
Yeah thanks. I just like to have a quick read to prepare before I do things to minimize any surprise
SK6 Service manual download? Retired SV Talk, Tuning & Tweaking 1 10-06-11 10:54 AM
Service Manual for SV650S 2001 and Service Recommendation stone SV Talk, Tuning & Tweaking 1 09-05-07 04:20 PM
Download SV650s K4/K5 manual online? markfc SV Talk, Tuning & Tweaking 3 20-01-05 09:55 PM
