Old 03-08-12, 11:46 PM   #1
SoulKiss
SoulKiss's Avatar
Default Clutch Adjuster and lock washer.
I am after the slotted bolt and lock washer that screw into the clutch perch.
Anyone got a spare knocking around?
Doesn't matter of its off a pointy or a curvy, a naked or a faired.
Thanks
Old 04-08-12, 01:05 AM   #2
squirrel_hunter
squirrel_hunter's Avatar
Default Re: Clutch Adjuster and lock washer.
Those bits are less than £5 from Suzuki, you'd be best off getting them from a dealer if I'm honest. Unless you want the whole worm assembly but thats £45 and even then considering I've had one fail I'd be splashing out on that.
But from my experience with this part I've got to ask... What have you done to it?
"A little enthusiastic?"
SH2 | 2MA | GROM | YSR
Clutch Cable Adjuster RichT Stuff Wanted 1 22-11-11 07:05 PM
Clutch Cable adjuster - where from? warrenhewitt10 SV Talk, Tuning & Tweaking 12 02-09-10 10:30 AM
Gearbox Oil seal and sprocket lock washer fig roll Stuff Wanted 3 09-07-10 04:05 PM
Clutch cabe adjuster Flameboy Stuff Wanted 1 20-11-09 04:52 PM
clutch cable adjuster kwak zzr Stuff Wanted 4 30-01-07 05:11 PM
