Old 17-08-12, 04:54 PM   #1
Elliott
Default Fork dust seal removal?
I have the parts and ATM only need to change the dust seals, can someone advise how to remove the old ones?
Ta
Old 17-08-12, 04:59 PM   #2
Default Re: Fork seals?
they pop straight off m8. piece of wood in the recess then tap them out.
Old 17-08-12, 05:38 PM   #3
If you mean the piece above the seal, external to the fork, then it's just a push fit, put a knife blade in the join and twist gently.
Old 17-08-12, 08:59 PM   #4
Fallout
Fallout's Avatar
Default Re: Fork dust seal removal?
I think he might be asking how to remove them from the forks. I'm guessing you remove the front wheel and callipers and pull them over the end of the forks. Do they stretch enough for that? Just guessing here.
MotoGoLoco - You knows it
Fallout Breakbeat (My Music)
Old 17-08-12, 09:29 PM   #5
jambo
jambo's Avatar
1st remove the fork.
The dust seals are quite thick and so have very little stretch in them. As Sid Squid says, get a butter knife or similar and run it round the top of the fork lower / dust seal bottom, and work the dust seal up out of the fork lower. Side the seal off the fork and clean up the recess before sliding the replacement on and in.
Refit fork.
Jambo
Old 18-08-12, 02:50 PM   #6
Elliott
Nice one guys gave it a go on a spare set of forks I have, need to do seals but going to wait as I may aswell uprate the forks at the same time.
Anyone know how to get forks springs cheaper than 115?
Old 18-08-12, 03:03 PM   #7
PM sv650racer http://forums.sv650.org/member.php?u=2186
Old 18-08-12, 06:55 PM   #8
Elliott
Have done, what am I asking tho! Lol
Linear or progressive I'm not fuses but from what I've read linear will match my needs as I don't hang about and often go on track.
Old 18-08-12, 09:11 PM   #9
Linear...
Old 19-08-12, 12:12 AM   #10
squirrel_hunter
squirrel_hunter's Avatar
There is every chance that I have misunderstood you. You know you need to replace the oil seals on your forks but have instead replaced the dust seals as you are going to change the springs at a later date?
"A little enthusiastic?"
SH2 | 2MA | GROM | YSR
Rear wheel dust seal - where from? Dunn-y SV Talk, Tuning & Tweaking 1 14-05-12 11:39 AM
rust under the front suspension dust seal cringer SV Talk, Tuning & Tweaking 13 12-06-10 09:57 PM
Head bearing, dust seal barwel1992 SV Talk, Tuning & Tweaking 3 06-05-10 07:56 AM
Front Caliper Dust Seal mikebrooman SV Talk, Tuning & Tweaking 5 25-02-09 12:50 PM
Brake dust seal has come out....Bugger creamerybutter SV Talk, Tuning & Tweaking 48 31-07-06 08:22 AM
