Old 15-09-12, 09:52 PM   #1
squirrel_hunter
squirrel_hunter's Avatar
Default Captive Wheel Spacers?
Can someone please explain to me how they work?
I have spent quite sometime, tonight for instance, arguing with bikes, wheels, and their spacers. Its an argument that I always win, it just takes too long. So it got me thinking those racers can change wheels quite quickly and they have yet to resort to evolving an additional set of arms (don't get me wrong an additional set of arms would be very useful I just don't fancy buying all new t-shirts just yet). I understand that they use captive wheel spacers to help them and I have seen them available for many bikes. But I was wondering how they work, how they are fitted, and why they are not standard?
"A little enthusiastic?"
SH2 | 2MA | GROM | YSR
Old 15-09-12, 10:06 PM   #2
Default Re: Captive Wheel Spacers
they work just like the sprocket spacer in that the spacer is 'captive' in the race so less likely to fall out when putting the wheel back on.
Old 15-09-12, 10:12 PM   #3
It boils down to cost, they aren't cheap.
I'm really considering swapping out on the rear for ease over the winter
Old 15-09-12, 10:18 PM   #4
squirrel_hunter
But what captivates them?
You say captive in the race. That makes me think of the bearing races, so an interference fit to them, would that not mean different bearings or spindle?
Old 15-09-12, 10:35 PM   #5
AndyBrad
They sit behind the dust seal for the bearing.
Hasn't yc got a lathe? He might knock you some up? ?
Sent from my GT-I9300 using Tapatalk 2
Old 15-09-12, 10:57 PM   #6
barwel1992
i thought the captive ones were just top hat spacers that sit inside the bearing rather than sitting against its face
although you could make some like above that use the standard bearings
i could possibly knock some up as well, would need measurements though as i don't have a sv any more and you'd need new bearings for top hat type
Old 15-09-12, 11:39 PM   #7
yes
Old 16-09-12, 07:05 AM   #8
Mr Speirs
Mr Speirs's Avatar
Lots of people on trackdayriders use them and swear by them.
They are the same as standard except they are machined so there is a slight lip on the side nearest the bearing. This lip sits behind the dust seal on the bearing and holds it in place.
Hope this helps.
Old 16-09-12, 09:52 AM   #9
squirrel_hunter
Hope this helps.
How is that possible with sealed bearing units like I see in my wheels?
Old 16-09-12, 10:57 AM   #10
mikerj
It doesn't fit behind the seal which is part of the bearing, they fit behind the outer "dust" seals, which AFAIK the majority of bikes have, even if they use sealed bearings within the wheel and sprocket carrier etc.
Curvy rear wheel spacers? carpet monster Stuff Wanted 4 25-08-11 12:09 PM
Wheel Spacers andrewsmith SV Talk, Tuning & Tweaking 2 25-08-11 08:03 AM
2003 sv650 onwards captive rear spacers bike_slider For Sale - SV's and SV related items 2 26-10-10 02:23 PM
Wheel spacers? northwind Bikes - Talk & Issues 15 17-07-09 05:28 PM
Wheel spacers K3? kenada SV Talk, Tuning & Tweaking 2 31-08-08 10:26 PM
