Old 03-05-14, 08:04 PM   #1
shurm
Default Fuel Exhaust Fitting?
Well I've got my new Fuel Exhaust, can someone tell me how long it should take to cut through the exhaust with a hacksaw !!! I'm at work tomorrow and wanted to do it before I go to work so want some idea how early I might have to get up
Old 03-05-14, 08:17 PM   #2
rictus01
rictus01's Avatar
Default Re: Fuel Exhaust Fitting
well how enthusiastic are you , 10 minutes max I'd say, but stop for a brew & a fag and it could take you an hour, personally I use a 10" grinder and it takes about 20 seconds.
Old 03-05-14, 08:21 PM   #3
shurm
Cheers its not that bad then only ever fitted slip ons before never had to cut through an exhaust before. Might have time to ride it as well then
Old 03-05-14, 08:24 PM   #4
rictus01
rictus01's Avatar
be aware it's double walled, there's an inside vented tube as well.
Old 03-05-14, 08:31 PM   #5
shurm
Ok thanks again at least I won't be surprised now
Old 04-05-14, 08:38 AM   #6
shurm
Well thats not happening got the heat shield off, taped up the footrest then just couldn't get a decent angle to make a start on the floor.
Plan B - get someone else to do it or get some proper tools
Old 04-05-14, 09:05 AM   #7
Kenzie
Kenzie's Avatar
At least your shield came off ok. My bolts had seized and ended up snapping! Why can't you get a good angle on it?
Old 04-05-14, 09:26 AM   #8
rictus01
rictus01's Avatar
Seriously ,
got to be the simplest of jobs, where are you (as you haven't put it in your profile), perhaps someone local can assist ?
Old 04-05-14, 10:26 AM   #9
shurm
Just at work now ran out of time a bit after getting the shield off, my bolt heads came off as well !!!
I'm in Accrington Lancs, I think once I get into it it will be ok but I was trying to do it on the garage on the floor. Might hire a saw midweek.
Old 04-05-14, 06:43 PM   #10
shurm
Well came home from work and went mad with the hacksaw ..........
and its on, couldn't even start it up because the babies are in bed, So I'll be up nice and early before work again tomorrow to listen to it and have a quick blast.
Cheers for the help everyone
Fitting a fuel gauge? granty92 Bikes - Talk & Issues 2 22-08-12 10:35 AM
Fitting Fuel exhaust - help please. silversurfer SV Talk, Tuning & Tweaking 11 04-08-09 01:12 PM
just got Fuel exhaust for Birthday, Weather=Cr*p!, fitting advice pls mattb200 SV Talk, Tuning & Tweaking 5 17-05-08 08:53 PM
Fitting Fuel Exhaust plowsie SV Talk, Tuning & Tweaking 9 26-05-07 01:24 PM
Fitting a Fuel Zorst DanDare Exhausts 11 22-05-07 09:23 AM
