Old 24-02-15, 03:36 PM   #1
Default curvy owners?
thanks to SH and Mav i now have a curvy swingarm, spindle, marker plates and nut.
i've had a good look at how things tighten up on the plates but i'm a bit concerned about the axle nut.
on the pointy the rear axle nut has a recess so the axle can be drawn into the nut if need be.
the curvy from what i can tell the rear axle nut is flush on the bottom so can only go down the threads on the axle so far which is the start of the taper on the axle.
could some curvy owners please check to see if the rear axle nut is indeed like the one i have and flush on the bottom.
thanks
Lance xx
Old 24-02-15, 07:38 PM   #2
garynortheast
garynortheast's Avatar
Default Re: curvy owners?
Can you put a picture up of what you have Lance? As soon as it's up I'll nip straight out to the garage and compare it.
Old 24-02-15, 07:48 PM   #3
here you go.
just a rear axle nut
Old 24-02-15, 07:53 PM   #4
garynortheast
Ok just a minute then and I'll go and spin the rear spindle nut of and have a look.
Old 24-02-15, 08:19 PM   #5
garynortheast
Here we are then...
Old 24-02-15, 08:29 PM   #6
thanks m8.
looks like the one i have is well used
just a standard self locking nut. there is a bit of a recess but nothing to worry about.
a lot less complicated than the pointy marker plates to do and i think i'l be able to get the curvy markers tight as fek with virtually no slop
just wish suzuki hadn't welded the bloody bobbin bracket where it is
Old 24-02-15, 08:36 PM   #7
garynortheast
thanks m8.
The nut in my pics is a 60,000+ miler! Those bobbin brackets are right where they don't need to be!
Old 24-02-15, 10:05 PM   #8
squirrel_hunter
squirrel_hunter's Avatar
There should be a washer behind that nut and before the plate as standard. Some bikes I've seen don't have the washer and I couldn't find a spare for you not sure if that's going to be an issue for you? Forgot to say before I sent it, sorry.
"A little enthusiastic?"
SH2 | 2MA | GROM | YSR
Old 24-02-15, 10:19 PM   #9
ahhh. i see said the blind man. i was wondering due to the rub marks on the spindle where it rests on the swingarm. should be ok as i'm increasing the spacing by 3mm due to using 4mm SS and the standard plates are 2.5mm mild. as with the pointy i'll still have to chamfer the outer/inner of the plates due to my working tolerances being a bit better.
Old 24-02-15, 10:41 PM   #10
garynortheast
Sorry, I should also have said that there is a thick washer between the nut and the plate.
Curvy Owners Manual & Workshop Manual - FREE Scythe92 For Sale - SV's and SV related items 5 11-01-15 06:32 PM
Curvy owners manual 2000 hannakournikova Stuff Wanted 6 31-03-12 05:08 PM
SW-Motech Rack help - I need curvy owners with one. CLARKYsv Bikes - Talk & Issues 1 09-08-10 09:25 PM
