25-09-16, 04:27 PM | #1 |
The dreaded engine swap
So, engine finally went pop.
Nothing too daunting, have dropped the engine on a R125, ZX7R, ZX9R, FZR600. Disconnected everything, all bolts out. Engine is still in the bike, what am I missing ? Seriously thought it'd take me a few hours. Just packed up after 6, scratching my head. Am I to drop disconnect the rear head before it all comes out ? 2007 SV650S Single Spark engine. On another note, I've got an almost new engine sitting in my shed. What can I do to it just to get a bit more power out of it ? More aggressive cams. What else do you guys think engine wise ? |
25-09-16, 10:25 PM | #2 |
Re: The dreaded engine swap
I've done this more than once.
No you don't have to remove the rear head, however you need to be sure you've removed and disconnected everything. Not all bolts go through the engine some just mount into the heads. I can't remember exactly how many there are, 6 probably. Assuming all bolts are out is there any movement in the engine, you should be able to rock the engine? If not the engine mounting adjusters might be holding the engine into the frame. They are castellated nuts and can be a little stubborn on occasion. If you have got movement check the rear exhaust pipe. If you still have the stub on the head it can catch on the back of the frame and prevent removal. As you take the engine out you need to move it forward slightly as it drops down. Other than that without seeing what you have removed it will be difficult to suggest what is presenting the challenge. Turning to the what to do with the engine question, the most common answer is a Cam Swap. Other than that, how much do you want to spend? Big bore, lighten flywheel, Hayabusa pistons, thinner head gasket, the list can go on. If you have cams to hand chuck them in. If not check the valve clearances and shove it in. |
26-09-16, 09:05 PM | #3 |
The engine is often wedged firmly between the centre mount's adjusters.
Engine Swap | lazymanc | SV Talk, Tuning & Tweaking | 18 | 25-04-11 11:15 AM |
k6 to k9 engine swap? | T0mmyGun92 | SV Talk, Tuning & Tweaking | 3 | 12-04-11 06:36 PM |
engine swap tips? | mouse8197 | SV Talk, Tuning & Tweaking | 1 | 16-05-10 04:45 PM |
Engine swap advice | sixstring | SV Talk, Tuning & Tweaking | 7 | 18-01-08 09:44 PM |
engine swap this weekend (hopefully all done on sat) | fat_brstd | Thames Valley | 17 | 23-09-07 09:02 PM |
