Old 14-11-17, 08:28 PM   #1
revjim2020
Default SV engine noise...ideas???
ok guys, any help is appreciated. I have a few sv's. This one is a 2001 SV650. It is high miles and was getting a slight ticking noise compared to my others so I took it to a shop for a valve adjustment. upon return it was WAAAY louder. (say like 4x).. It sounded like something was bent badly. This is in the front cylinder only. sounds like metal tapping....like a car with a bent pushrod or something. I took it to another shop, who said all valves are within spec. He did some visual checks and found nothing. It has good compression, power is fine. The tech said he isn't sure what it could be but will be glad to pull it apart for 500 or more..... I am sure the first shop probably damaged something and re adjusted , but any ideas what it is?
Old 14-11-17, 10:02 PM   #2
Default Re: SV engine noise...ideas???
its a jammed cam chain adjuster, common fault. you need a special shim key to service them or when replacing the valve shims (take the cams out). common upgrade is to put pointy ones in.
the other i have found that makes curvy's rattle is them needing the carb vacuum balanced.
Old 14-11-17, 10:04 PM   #3
garynortheast
garynortheast's Avatar
I'd take a look at the cam chain tensioner. They do sometimes tick on curvys, but without any ill effect. If yours is worse since the shop played with it they may have taken it out and failed to replace it correctly. Take it out yourself and reseat it properly.
Blue Curvy S with over 111,000 miles and still going strong.
Old 14-11-17, 10:06 PM   #4
garynortheast
Beat me to it Lance!
Old 14-11-17, 11:43 PM   #5
squirrel_hunter
squirrel_hunter's Avatar
Not in my experience. You will just need a small flat blade screwdriver. The key is if you wish to "lock" the tensioner in the withdrawn position, I've never needed to do this.
I'm not sure what is meant by "service them" either? They are a single unit with no replaceable parts as far as I am aware. Essentially all you can do is wind out the adjuster which is needed when installing.
"A little enthusiastic?"
SH2 | 2MA | GROM | YSR
Engine noise - K6. Xpistos SV Talk, Tuning & Tweaking 4 11-02-13 12:50 PM
k4 engine noise on over run all the gear SV Talk, Tuning & Tweaking 2 28-08-11 06:57 AM
total mechanical amateur - Clunking noise when accelerating? Any Ideas TechJinx SV Talk, Tuning & Tweaking 10 23-06-09 01:27 PM
Suspicious noise when riding, any ideas? TheStudent SV Talk, Tuning & Tweaking 10 24-07-08 07:46 PM
engine noise. cmc1 SV Talk, Tuning & Tweaking 24 12-06-08 11:32 AM
