Old 13-08-05, 08:44 AM   #1
red5
Default Scorpion SS, removing baffle cause running problems?
Hello, I'm thinking of getting a scorpion can with removable baffle and running it without it in, I realise this can cause problems on some bikes cos of the change in back pressure.
Anyone know if I did this on my curvy-s, if I'd need to get the bike tuned to allow the engine to work with it properly - or prevent problems.
Ideally I'd just like to fit it and be done with it
Old 13-08-05, 10:49 AM   #2
you should'nt have any problems i've fitted one to my pointy and have no problems at all. the only time you may need your fueling looked at is if you fit a performance air filter aswell. your scorpion can will sound great on your curvey and pop nicely on the over run! enjoy
Old 13-08-05, 11:02 AM   #3
Cloggsy
Not true... Pointies have Fuel Injection which will rectify itself (to a certain degree) & it will runn correctly with minor changes, curvies have carbs which don't have the ability to rectify themselves...
If you want it to run 'baffle out' it'll need some work done & perhaps Dyno'ing
Old 13-08-05, 07:49 PM   #4
i put a can on my cbr with no fueling problems thorght sv would be the same.
Old 13-08-05, 08:06 PM   #5
Richie
fantabulas
Richie's Avatar
hope this is correct. if not correct it / me please.
CBR has less engine braking, a smaller engine, 2 more cylinders. which='s less back pressure on scavaging the exhausted gases out, so less problems.
My Flickr photos
Old 13-08-05, 11:33 PM   #6
Dan_SV
Stubby high level scorpion on mine (tis a curvacious one), with no baffles in the can, nor any of that faff in the collector either (mr holesaw made an appearance). Runs fine. You can get away running a can by itself on most SV's (I'd hazard a guess at 95% being ok). Its only when messing about with the induction side of things you will tend to run lean. With a standard air filter, and the pipe, mine is still running slightly rich in the midrange.
Danno.
P.S. The SV's FI system has no provision to "self correct" itself. Tis a common myth.
Old 14-08-05, 08:00 AM   #7
thanks for clearing that one up dan sv! my knowledge it limited!
Old 14-08-05, 08:04 AM   #8
richwill68
Hi mate!
Put a Viper race can on my curvy, no other mods' and it works fine! If you're at all concerned, get it on a dyno' and have them set up the carbs' for you.
Regards
Rich
Old 14-08-05, 11:36 AM   #9
M.C.
M.C.'s Avatar
i had a scorpion race can on my curvy and it ran fine and now i have a remus revolution on my K5 and that runs fine but dynoing is the only way to get it set up right
as for the fuel injuction models rectifying their self i don't think they do because there are no lamda sensors on the exhaust so no way of the ecu getting a reading (i stand to be corrected though)
M.C. is offline   Reply With Quote
Old 14-08-05, 03:11 PM   #10
WelshWop
Ive got a ccc race can on my curvy. Had it dyno'd, fuelling was fine and it made an extra 3bhp and 0.5ft-lbs of torque.
Baffle to fit Scorpion end can jambo Stuff Wanted 3 19-08-08 08:04 PM
Scorpion baffle Bear Stuff Wanted 3 05-04-08 07:38 PM
Removing a baffle from an akrapovic Zombie Jesus Bikes - Talk & Issues 10 13-02-08 11:15 PM
Removing a baffle from ccc can Kirmit Exhausts 7 09-02-06 10:43 AM
SCORPION BAFFLE..... alexb SV Talk, Tuning & Tweaking 7 28-02-05 09:49 PM
