Old 26-09-06, 09:35 AM   #1
MarkyBoy
Default Engine Burning Smell
Mornin all,
after my normal morning commute I pulled up to be greeted with a potent smell of burning, as if the engine had no water in it???? now I can see the radiator cap on the right, but I have lowers and its a nightmare to get to, is there a overflow reservoir anywhere or an easy way to check my water levels as cant be taking lowers off without tools.
alternatively, maybe its something other than water? all suggestions greatfully received.
thankyou muchly in advance!
Old 26-09-06, 09:39 AM   #2
lukemillar
Were you riding in rain/ had it been raining?
If so water collects in the radiator as you ride, heats up and gives off that smell - nothing to worry about! It will also dribble out when you put your bike on it's side stand.
You can check the coolant, by looking at the reservoir on the left hand side of the bike between the frame.
Old 26-09-06, 09:51 AM   #3
MarkyBoy
no rain here, lovely sunshine all the way!
Old 26-09-06, 10:00 AM   #4
K
Maybe it has something to do with your bike being on fire.
Sorry, I'm in one of those moods.
Um... something constructive... have you checked there's not something stuck to the exhaust?
Old 26-09-06, 10:52 AM   #5
Red ones
Red ones's Avatar
You can do that without removing OEM lowers.
Old 26-09-06, 01:04 PM   #6
MarkyBoy
Lunchtime update!!!!!!
examined the coolant and its just above L so yes its low, but not empty
then as I turned the steering to get a better view of the underside the horn swang into view, YEP just hanging by the connecting cable!!
so now I am wondering if the horn had somehow been lodged somewhere causing heat to transfer to somewhere it shouldnt causing the smell?
also I am obviously a little concerned how the horn has come to be just hanging?
any quick suggestions as to where I need to look as to where the horn should be fixed? I cant see anywhere obvious?
cheers
Old 26-09-06, 01:26 PM   #7
Kilted Ginger
PM Tiger 55, His fell off last week, sure he knows where it goes.
http://forums.sv650.org/viewtopic.php?t=44979
Old 26-09-06, 02:25 PM   #8
MarkyBoy
cheers Ginger, will do!
Burning Smell crzylanesplit SV Talk, Tuning & Tweaking 23 05-02-09 12:34 PM
Burning smell - advice please. Vespillo SV Talk, Tuning & Tweaking 15 29-12-08 09:00 PM
Burning smell Baz SV Talk, Tuning & Tweaking 10 04-07-08 09:01 PM
burning smell steveg SV Talk, Tuning & Tweaking 18 31-01-08 06:13 PM
help i smell burning wires vsumouse SV Talk, Tuning & Tweaking 6 25-05-06 09:22 PM
