Old 16-02-07, 09:52 PM   #1
danf1234
Default The Dremmel
I am going to attempt to the use a dremmel to take of my old exhaust to fit a Remus. However it really doesn't look up to the job to me.
Is it really possible?
Has anyone on here tried it? And what are the pitfalls to look out for?
Is there a method I should follow to do it?
Any help greatly appreciated thanks,
Dan
Old 16-02-07, 10:51 PM   #2
socommk23
use a hacksaw
Old 16-02-07, 10:54 PM   #3
Demonz
Use an angle grinder!
Old 16-02-07, 11:20 PM   #4
Richie
fantabulas
Richie's Avatar
Use great care... and a new hacksaw blade.
My Flickr photos
Old 16-02-07, 11:28 PM   #5
squirrel_hunter
squirrel_hunter's Avatar
I think an angle grinder would be best as the standard exhaust is double skined (on a curvey at least).Though I imagine that it would be possible but probably not the cleanest of cuts with the Dremmel. Also if you do go with the Dremmel use the heavy duty cutting discs as the standard ones will only last a couple of minutes.
"A little enthusiastic?"
SH2 | 2MA | GROM | YSR
Old 17-02-07, 09:18 AM   #6
pmapp
pmapp's Avatar
Hacksaw - took me 10 mins.
Take off the footpeg to give you a bit more room,
Draw a line so you got something to follow, 40 - 50mm from the weld I seem to remember,
Cut away..........
A dremel will take ages, and use a fair few cutting disks.
Once you have it off remember to fire it up - just to see
Old 17-02-07, 09:26 AM   #7
timwilky
timwilky's Avatar
only takes 2 minutes to cut with one of these
http://www.machinemart.co.uk/images/library/products/large/000310020.jpg
Not Grumpy, opinionated.
Old 17-02-07, 10:05 AM   #8
i took me less than that with a grinder and the cuts neat.
Old 17-02-07, 10:06 AM   #9
just cover the swing arm and back wheel ect with cardboard to stop the sparks causing any damage.
Old 17-02-07, 02:05 PM   #10
DoubleD
I found the dremmel cutting disks just disapear before your eyes and don't do much cutting.
